It is currently Sat Jan 20, 2018 9:37 am
Post new topic  Reply to topic  [ 74 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Tue Sep 19, 2017 2:41 am
FWIW...it may not be the rotor. What about your caliper? Not sure which caliper you are using, but the pistons of some calipers don't retract very well. I've been having issues with my front RS685 caliper. Bled the brake and it is now better, but not quite perfect.
MoPho wrote:
I haven't had much luck with the ice-tech rotors. For some reason I was getting an issue where the pads were pulsing and scraping over the vent cut-outs on the rotors as I got below 20mph under harder braking. Changed pads and it would go away for a little while, then come back. Same if I changed rotors and/or cleaned and sanded the pads. Tried both RT99 and RT81 140mm and 160mm. Same thing every time. Seems I am the only one with this issue as none of the other disc guys around here are experiencing it with the ice tech.
Now trying the Sram Centerline and the issue has gone away seemingly because of the shape of the venting, but not sure yet if the braking is as good with them. Already had a hard stop from 40-0 mph that overheated the rotors, may have been an anomaly.
:noidea:
PostPosted: Tue Sep 19, 2017 3:15 am
I don't think it's the venting...it's the shape of the rotor's outside and inside edge. If you look at the various Ice Teh rotors, they are severely notched on the outside. The RT-99 and RT-900 are also severely notched on the inside where they mate with the heatsinks. I've had this problem with the Ice Techs and have since switched to SRAM Centerline X and also tried the new Campy H11 rotors.
TBH the SRAM rotors are the best in terms of braking noise. The H11s make a "cool" noise under braking with their aggressive venting. Some rub after strong braking is kind of the norm. Once the rotor, pad, etc. cool down, the contact goes away.
PostPosted: Tue Sep 19, 2017 3:54 am
I have the RS805. I had not considered the pistons not retracting because it happens when the brakes are being applied firmly, but something to look at.
Yes, you are correct it seems to be the outer notches causing the issue. Glad to hear someone else has had this happen. No one around here has experienced it, which you would think it would happen to all of them :noidea:
When I was on the 140mm ice tech there would be that rubbing after a hard brake event for a few seconds till they cooled, interestingly I did not get it with 160mm rotors. I have to do some more testing with the Centerline
The centerlines look great on the bike though :mrgreen:
Website | Instagram
PostPosted: Tue Sep 19, 2017 4:55 am
Let me know if you get sharp pings on your Centerlines after long hard descents. It seems to be the result of the alloy carrier and steel rotor expanding and contracting at different rates. It's the only issue I've had with the SRAM rotors and it's not performance related.
PostPosted: Tue Sep 19, 2017 5:58 am
Video/audio example on a descent today.
PostPosted: Tue Sep 19, 2017 6:35 am
Awesome! What speeds were you doing?
PostPosted: Tue Sep 19, 2017 6:45 am
Was it the brakes or was Chewbacca in the saddle :D
PostPosted: Tue Sep 19, 2017 7:23 am
Max speed was probably around 45mph / 72.5km/h. On some other segments I touch 50mph / 80.5km/h, but the roads here aren't usually steep and straight enough to go faster than that. Also I'm fairly light, so I don't pick up speed when the air is particularly dense like it was today.
PostPosted: Tue Sep 19, 2017 8:07 am
I haven't had that happen yet.
Are you ceugene on the other forum?
NorCal?
Website | Instagram
PostPosted: Tue Sep 19, 2017 8:27 am
NorCal?
Yes and yes.
PostPosted: Tue Sep 19, 2017 9:35 am
Yes and yes.
Well I guess you're not the 2nd person I've found that has had this issue LOL
Website | Instagram
PostPosted: Tue Sep 19, 2017 11:50 pm
Interesting MoPho - what calipers are you using ? I'm on the 4 piston Zee, so with the bigger pad, it may be a very different result.
I have also used Avid HSX and had overheating problems on some descents that I never had with any other rotors (same pads and speeds). They got binned real quick.
PostPosted: Wed Sep 20, 2017 2:24 am
I think SM-RT900 is the best disc rotor for road-bike.
PostPosted: Wed Sep 20, 2017 2:56 am
They're all about the same weight...hovering around 120g for centerlock rotors. The only major difference is the fins and the aluminum middle layer. I don't think it's a big deal, and it definitely wasn't worth dealing with the weird pulsing issues resulting from its shape.
PostPosted: Wed Sep 20, 2017 3:32 am
I am using the RS805 and I think the smaller pads have a lot to do with the issue.
Are you using the Zee calipers on a road bike? Disc naysayers often use lack of traction as an argument but I feel like I could use even more power in the dry, 4 piston brakes would be interesting. :twisted:
Did a good 5 mile technical descent today and the centerline rotors seemed to hold up well, including a panic stop when a deer ran out in front of me. :shock:
Website | Instagram
There are no new unread posts for this topic. Attachment(s) 140 front disc rotor
[ Go to page: 1 2 3 4 ]
ooo
52
2948
Mon Nov 13, 2017 2:48 pm
uraz View the latest post
There are no new unread posts for this topic. Is disc rotor size frame-specific?
Miller
9
1038
Wed May 24, 2017 8:35 am
lwk View the latest post
There are no new unread posts for this topic. Attachment(s) Why is no one using disc brakes in the tour?
[ Go to page: 19 10 11 12 13 ]
gceniza
186
18164
Sat Jul 22, 2017 8:29 am
lobuxracer View the latest post
There are no new unread posts for this topic. Disc brakes : new pads = brake rub??
Delorre
9
1102
Mon Oct 23, 2017 11:36 am
CBJ View the latest post
There are no new unread posts for this topic. Attachment(s) In a 2017 ww world - what is the weight penalty of running disc brakes?
alcatraz
Sat Mar 18, 2017 5:53 pm
nemeseri View the latest post
Users browsing this forum: 2old4this, Baidu [Spider], Bing [Bot], maxle and 44 guests
