Cannondale Caad12 BB30a
Peeza21
by Peeza21
I have a 2017 caad 12 with a BB30a
I have been offered the below cranks in bb30 and was wondering if they would fit? I am very untechnically gifted, so before committing I'd hope the experts on here could help. Thanks
Ltyarbro42
by Ltyarbro42
Short answer: no they won't. The spindle is too short.
goodboyr
by goodboyr
Ltyarbro42 wrote:Short answer: no they won't. The spindle is too short.
Really?? I think you are wrong......
http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=144719
Ltyarbro42
by Ltyarbro42
BB30A is wider than BB30. I made the same mistake OP is about to make. I bought a power meter with BB30 and I can confirm, it does NOT fit.
goodboyr
by goodboyr
Ltyarbro42 wrote:BB30A is wider than BB30. I made the same mistake OP is about to make. I bought a power meter with BB30 and I can confirm, it does NOT fit.
He's not talking about a power meter. He's got a red bb30 crank. You remove the preload adjuster from these cranks and use a wave washer to gain the extra width. Read the thread......
Ltyarbro42
by Ltyarbro42
No shit? I mistakenly got a crank based power meter for a BB30 when the BB30A standard was new. It did not fit. Period. Wave washers do nothing to lengthen a spindle.
You can put a BB30A crank to a BB30 bottom bracket. Not vice versa.
Sent from my ONEPLUS A3000 using Tapatalk
AZR3
by AZR3
So the new sram red crank with the hidden bolt fits BB30a, since cannondale specs that on the eTap Hi-Mod, does anyone have spindle length comparing the old and new?
raffit78
by raffit78
104 mm (old) and 109mm (new) are the two lengths of spindles
AZR3
by AZR3
^^thats the lengths of the old/new Red BB30 cranks? Couldn't find anything difinative on google.
srshaw
by srshaw
I doubt it would fit, spindle not long enough. SRAM Force funnily enough has a longer spindle (or so they recon on the cervelo forum) and would fit. No help to the op though.
deek
by deek
This crank will not fit on BB30A. The newer version with the hidden bolt will if you remove the threaded preload adjuster and replace it with a wave washer and plastic shims.
TarugoKing
by TarugoKing
Wondering if you are replacing a HollowGram Si on your CAAD12? If yes, why would you?
raffit78
by raffit78
AZR3 wrote:^^thats the lengths of the old/new Red BB30 cranks? Couldn't find anything difinative on google.
I apologize I was referring to the hollowgram spindle sizes.
These have two sizes 104 (older) 109mm (newer)
