Front derailleur limit screw rounded off (SRAM eTap), need plier recommendation
by Shrike
Something that will fit in there to try and turn it from the inside. Will need to be super thin, but stiff and grippy. Had a look around, too many options, not sure what to go for :hmm:
by RyanH
Search for spiral screw extractor set. That's the correct tool for the job.
Sent from my SM-G930V using Tapatalk
by sungod
^this, though i think the screws are titanium which makes it harder to work on them if you need a hole for the extractor, but maybe one will grip in the rounded socket
also, try using a torx/similar bit
which screw is rounded? the upper is reverse threaded, for that you might be able to screw a standard threaded bolt into the head to remove it
by Shrike
Thanks guys, it's the bottom one. Going to search for that set now :D
