probertsqbe wrote:I used this method https://moltenspeedwax.com/pages/clean-your-chain when I was testing out the benefits of waxing on chains.
Are you still using this method? If you're not, care to say why?
CrankAddictsRich wrote:This year I jumped to moltenspeedwax and can't be happier. Not only is friction reduced, but the drivetrain cleanliness is second to none. I hate dirty chains and chainrings and the wax has basically limited this.
BdaGhisallo wrote:CrankAddictsRich wrote:This year I jumped to moltenspeedwax and can't be happier. Not only is friction reduced, but the drivetrain cleanliness is second to none. I hate dirty chains and chainrings and the wax has basically limited this.
I am all set for the initial procedure to get up and running with the wax, but what are you doing for re-waxing? Are you washing the chain with anything (soap? solvent?) or do you just re-submerge it in the hot wax and go from there?
BdaGhisallo wrote:probertsqbe wrote:I used this method https://moltenspeedwax.com/pages/clean-your-chain when I was testing out the benefits of waxing on chains.
glepore wrote:Not exactly Rich. I'm waxing, but stripping old wax or grunge off after 500 mi or so dry use with a us and cleaner. Its the method advocated by moltenspeedwax etc. Yes, you could just dump your chain in the wax without cleaning, but that's not necessarily optimal.
