It is currently Fri Oct 20, 2017 10:28 pm
Post new topic  Reply to topic  [ 58 posts ]  Go to page 1 2 3 4 Next
PostPosted: Mon Apr 24, 2017 11:42 pm
I've been running a specialized S works saddle for some time now. Ideally, I'd love to keep the sworks saddle for the carbon rails and shell, but would love to have level 2 padding (Which comes on the comp and expert).
Has anyone torn down a power saddle that would be able to give some information on a sufficient way to possibly swap the padding? Seems to me, it would just be held on with glue?
PostPosted: Tue Apr 25, 2017 1:47 am
There are some good companies that cover saddles. I don't know where you are located, but here's an example of a top notch company.
http://busymanbicycles.blogspot.com/
www.ergottwheels.com
PostPosted: Tue Apr 25, 2017 7:24 am
These saddles seem to incredibly popular. Very tempted by one.
PostPosted: Tue Apr 25, 2017 8:35 pm
^ get it, it's great.
i have only one saddle that i like more than the Specialized Power Saddle.
Which is Shimano Pro Stealth, it is quite similar to the Power saddle but with even wider nose, wider cut out and more progressive widening profile toward the back (a bit more like a triangle than a peach than power saddle). At lower price point. (check price from starbike, it's great).
After all, even if it is very similar, it's still different so get a Power saddle if you tried one and really like it.
PostPosted: Tue Apr 25, 2017 9:13 pm
Perfect timing! I was looking at Shimano Pro Stealth for quite some time. Since it's new, availability is limited. How's the padding on it and how's the profile? Is it flatter or semi-round like Specialized saddles? Widening profile towards the back was a negative for me. Specialized Power saddle felt utterly wide. 143mm felt like 168mm hence I'm back on Romin Evo saddle.
:nospamhere:
PostPosted: Tue Apr 25, 2017 9:19 pm
They must fit a particular body type very well. I can ride 200 miles on a Sella Italia SLR but can't ride 5 miles on the power saddle.
PostPosted: Wed Apr 26, 2017 2:42 am
Side note: I always wanted to try the Power.
I had a Fizik Ares lying around (wich is very similar in shape) and though I would give it a try.
It's now my everyday road saddle, love it !
Lighter than the Power Pro and 1/3 the price :beerchug:
Might tear it down when it's worn.
Louis :)
PostPosted: Wed Apr 26, 2017 2:59 am
some photo side by side may answer some question.
Wider in the nose, narrower at rear end.
it is quite a bit flatter than the Power. Padding is only a tiny bit thicker than the pro level power which i believe it is the same thickness as the s-works one. It feel a lot better to slide front and back than a single position Power saddle.
Sent from my Nokia 3310 using GPRS
PostPosted: Wed Apr 26, 2017 3:17 am
That's the non carbon 143mm one?
Using Tapatalk
PostPosted: Wed Apr 26, 2017 3:21 am
both are 143.
Power is the Titanium rail, Pro version.
Pro Stealth is carbon rail, which is cheaper than titanium rail Power saddle.
PostPosted: Wed Apr 26, 2017 3:26 am
Very tempted to try the Pro. The Power is 95% right, Roman is great but too long.
Using Tapatalk
PostPosted: Wed Apr 26, 2017 3:38 am
Are the Power and Pro Stealth both made by the same company (Velo)? They look similar in construction, right?
PostPosted: Wed Apr 26, 2017 3:44 am
Thanks for pics! The nose is wide for sure. Wouldn't this cause some rubbing? What's the purpose of wide nose?
Beside Shimano Pro Stealth I'm also considering SQ Labs http://www.sq-lab.com/en/sqlab-ergonomi ... ve-de.html
I really tried to like the Power saddle but it's just too damn wide. I doubt that Specialized will introduce the 132mm.
:nospamhere:
PostPosted: Wed Apr 26, 2017 5:01 am
It cause rubbing when i sit far back when i first got it but then i adapt to have my leg parallel instead of leaning in. It never been a problem when i sit quite forward or near the nose.
Wide nose made the nose very very usable and i end up sitting near the nose for most of the time. I slide back to use back part of the saddle mostly on climb. I use nose mostly when doing a big effort pulling. All other time are somewhere in between.
The Power saddle made the saddle short so you can push saddle further forward without going pass through 5cm behind bb rule.
The Pro Stealth made the nose very comfortably usable so you can sit on the nose as long as you like without feeling bad.
PostPosted: Wed Apr 26, 2017 7:24 am
To me this kind of saddles is just like a stubby Tri/TT saddle (think Fizik Tritone/Mistica). Just got the Pro Stealth Carbon and will try it asap to see how it compares with Tritone 5.5 (Kium) and Prologo Scratch Pro CPC PAS (Tirox).
There are no new unread posts for this topic. What power meter on sworks 2018 sl6?
dedobike
20
1224
Fri Oct 06, 2017 2:53 pm
flyingbink1 View the latest post
There are no new unread posts for this topic. Specialized Power Expert Saddle - Weight
velobob
Mon Jun 05, 2017 4:16 am
chazmtb View the latest post
There are no new unread posts for this topic. 2015 Sworks Tarmac BB issue
SworksJake
Mon Mar 13, 2017 6:06 pm
SworksJake View the latest post
There are no new unread posts for this topic. Looking Inside an Sworks Tarmac Fork
cyclespeed
Fri Nov 25, 2016 7:44 pm
cyclespeed View the latest post
There are no new unread posts for this topic. 2016 Sworks build bits missing?
oreoboreo
Tue Mar 07, 2017 12:09 am
oreoboreo View the latest post
Users browsing this forum: mike001100, raggi, wingguy, youngs_modulus and 39 guests
