It is currently Fri Dec 15, 2017 3:47 am
Post new topic  Reply to topic  [ 192 posts ]  Go to page Previous 19 10 11 12 13 Next
PostPosted: Wed May 10, 2017 12:21 pm
ooo wrote:
which fluid campy uses? dot?
from bikerumor article
"Campy says they’ll be selling their own branded oil, but mentioned that it was blue and being produced by manufacturing partner. They were leaving it up to us to infer that it will be the same or similar Royal Blood mineral oil that Magura sells."
PostPosted: Wed May 10, 2017 1:46 pm
morrisond wrote:
sawyer wrote:
morrisond wrote:
Here you go..from Peloton
It seems as though the tipping point has been reached. Road disc is not just an option, very shortly it will be the only option for a high-end bike, relegating rim brakes to the bike path. With Campagnolo launching its road disc brake components, H 11, every major component group manufacturer has an attractive disc braking option. For all those disc brake deniers out there, just remember, every argument being made against disc has already been made, over 10 years ago, when mountain bikes went disc. We don’t see any serious rim brake mountain bikes anymore, and we won’t see any serious rim braking road bikes in five years time.
What an ignorant comment from Peloton.
Equally ignorant would be deny that disc brakes have some advantages
The dis-advantages for road are distinct from MTB requirements, namely a premium on weight and aerodynamics
Up to the end user whether those drawbacks are outweighed by superior stopping power
Just to be clear - although that quote was attributed to me (I don't agree with it at all) it was a partial quote taken from when I posted the Entire cached Peloton article that was taken down as they released the info too soon.
However I have seen enough stuff that it sounds like the Aero Penalty is minimal at worst and with good design can be mostly if not fully negated.
I've had enough Disc bikes now - starting with with Avid Mech's 12 years ago - to RS685's and now on SR with Spyre's on my gravel bike that I'm really not a fan - due to the noise issues. They all make a great racket at points - especially when wet or dirty.
That being said Campy Carbon rims with Campy pads make noise as well (although they do work quite well).
The part about the new Campy Brakes that has me very intrigued about is the supposedly lack of noise.
I'm still just P*ssed about the lack of Post Mount.
I've been in touch with Hope and they are going to Test their RX4's with Campy levers, and Magura Calipers use the same fluid as Campy (and they make the Campy Calipers and Hydro Parts in the levers) so I would guess they would work.
Let's just hope Campy will sell the levers separately like Shimano does.
I know - it wasn't attributed to you by me though ... I was very careful to say "from Peloton".
As far as I know there is some aero penalty, which might be small but it's there, and of course a weight penalty, which as things stand isn't small in the context of the weights obsessed about on here.
Campy pads on campy rims I ride everyday and like the sound. It's aeronautical at worst ...
:beerchug:
PostPosted: Wed May 10, 2017 2:33 pm
:beerchug:
I like the sound of Campy pads and rims as well - i'll take the sound for the braking performance - but I would prefer Silence.
The weight penalty is the big one - but it seems like it's down to less than two pounds for the hardware (levers/brakes/discs/hubs +400-600 grams - frame maybe 50 grams - fork +100 grams at best - thru axles + 50 grams - but that would assume same size tires/width of wheels/frame.
With where tire widths are going with People using discs - it all adds Weight - wider tires - wider rims - heavier tubes - frame heavier as it's wider - it's more like a 2-3 pound penalty now, however the bikes are a lot comfier to ride.
It's still not impossible to get under 6.8kg - but definitely a lot harder!
PostPosted: Wed May 10, 2017 3:08 pm
Campy's latest RIM pads (the ones made in the last year) are fantastic... I noticed it on Potenza and they have an updated pad on the Centaur group as well.
We did all of the descending on these pads that we did on disc and they're consistent, quiet and modulate extremely well.
Campy have maybe their biggest win with one of the least expensive bits they make...
charles@pezcyclingnews.com
PostPosted: Wed May 10, 2017 3:52 pm
Have Campy's red pads for carbon rims changed in the last year? If so, I hadn't noticed. They have always been superb imo and I too like the sound they make. I wonder if it's due to the cutouts. I have a set of the red pads for Shimano 9100 brake shoes that I'll be trying out shortly, and the cutouts are somewhat different. I'll be able to compare the difference using the same rims (Boras).
Colnago C60 - PR99
C59 Five Years Later
My Special Colnago EPQ
Trek Emonda SL Campagnolo SR
PostPosted: Wed May 10, 2017 4:59 pm
Not sure. These rim pads were for alu... And they were awesome.
PostPosted: Wed May 10, 2017 5:21 pm
I would not be able to notice either as not only are they fantastic, they also last forever. Have 9000km on one of the set and they are half way thru, and I do not live in Miami.
PostPosted: Wed May 10, 2017 9:04 pm
How can the new pads be recognized?
PostPosted: Wed May 10, 2017 9:09 pm
hmmm.... good question. I'll ask
PostPosted: Wed May 10, 2017 9:13 pm
Calnago wrote:
Yes, and I have a set of Magura Hydraulic rim brakes coupled with their hydraulic road levers (HS77) made for only one season I think but never took off since they weren't compatible with ergo/sti shifters, so you had to use either downtube shifters or bar ends. Great brakes. But now, things have changed and they can mix hydraulics with the shifters. Therefore I see no reason that nice hydraulic rim calipers for road bikes couldn't be the ultimate goto option over discs on high end road bikes. Unless you want to run huge tires, are there really any advantages to discs on a road bike? Versus a nice set of hydraulic rim calipers? The ease of action and modulation comes from the hydraulics, not the discs themselves. A road bike is rarely if ever subjected to mud deeper than the rim profile, in which case yes, discs are preferable hence they are on mountain bikes. So, unless you want to run huge tires on your road bike, like 30+ mm and clearance becomes an issue, I would totally opt for hydraulic rim calipers with some nice levers to match. No extended chainstays to mess up the tight road bike handling characteristics we've come to enjoy. No frame beefing up. No wheel beefing up. Same ol, same ol, except for the added light action of the rim brakes being activated hydraulically rather than via a cable. Oh yeah, and a little less of that thing we refer to here as weight. But who cares about weight, right?
Of course, this would mean that the sea change of new frames etc., and the obsolescence of all existing road bikes would not happen, and I could see that as being frowned upon by the manufacturers who are licking their financial chops at the prospects here.
So come on Magura, and any other brake manufacturers that see this as a huge opportunity. Bring it!
Indeed. I for one would love to see an updated, hydraulic version of Campag's Delta brakes.
Cinelli Saetta (Chorus/Athena EPS, Tune/3T) 6.5kg
Reilly T325//RC (Chorus/Athena EPS, fi'zi:k) 7.3kg
Pinnacle Dolomite (Athena, KCNC) 7.8kg
M∆SON Definition (Chorus/Athena EPS, 3T) 8.5kg
Raleigh Quadra (Dia-Compe, Velo Orange) 11.4kg
PostPosted: Wed May 10, 2017 9:34 pm
If they're significantly better than the old ones they must be incredible. I did thousands of miles on the set that came with my Record brakes about 5 years ago and they still looked brand new when I got rid of that bike. By comparison the SRAM (by Swissstop) black pads that came with the Red brakes on the next bike were less powerful, more spongy, more grabby, more noisy and wore at least 3 or 4 times faster, all on the same set of wheels.
PostPosted: Thu May 11, 2017 9:34 am
Going by the logic in the article above, I'm looking forward to eBay being awash with mechanical rim brake frames :)
PostPosted: Thu May 11, 2017 7:09 pm
For those of you on Linkedin - Joshua Riddle - Campy Global Press Manager who is quoted in a lot of the press on Disc Brakes can be contacted through Inmail if you would like to help lobby for Post Mount. Most of the Campagnolo Managers are in there.
PostPosted: Thu May 11, 2017 7:59 pm
How is Campagnolo today? I don´t wanna flame war, just asking those, who can compare...guys from my bike shop (they sell Bianchi and do sell Campagnolo) told me that they would not put Campagnolo on their personal bikes. It´s harder to tune and when tuned it lasts less compared to Shimano...they told me they would prefer Shimano 105 to any Campagnolo groupset..
Is Campagnolo front derailleur 100 percent OK with non Campagnolo chainrings or the performance is affected?
Is Campagnolo rear derailleur 100 percent OK with SRAM/Shimano cassette (I already have and my wheels have this rotor) or the performance is affected?
Thanks a lot!
They are...
It's funny but both this launch and the last, despite all the flashy stuff shown costing multiples of multiples more money, pretty much all of the media, regardless of country, were commenting on the rim brake pads...
There are no new unread posts for this topic. Attachment(s) Campagnolo 80th groupset
Boshk
7
748
Tue Oct 10, 2017 1:24 pm
joe1234 View the latest post
There are no new unread posts for this topic. campagnolo or shimano groupset....
[ Go to page: 1 2 3 4 ]
Boshk
48
5123
Wed Oct 04, 2017 10:25 am
Daniel1975 View the latest post
There are no new unread posts for this topic. Suggestions for short cranks with Campagnolo groupset
syplam
Mon May 01, 2017 9:25 pm
AJS914 View the latest post
There are no new unread posts for this topic. Attachment(s) Octalink Groupset Upgrade
Lewski33
11
1230
Sun May 14, 2017 9:20 pm
Lewski33 View the latest post
There are no new unread posts for this topic. FSA K-Force WE Wireless Electronic groupset
Miller
Thu Jul 13, 2017 6:50 am
Ritxis View the latest post
Users browsing this forum: evan326, kookie, shillc and 22 guests
