Exustar pedal body parts?
by loudtiger
I have a pair of well-loved carbon Exustar Look-style pedals (E-PR200CKTi, titanium spindle/carbon body) and the part where the pedal springs into the cleat is worn down to where it will no longer grab the cleat securely. Does anyone know if this part is replaceable? I would hate to junk the pedals as they're one of the lightest out there. Here is a picture: https://drive.google.com/file/d/0B1HO4p ... sp=sharing
You can see the wear on the right pedal; the left pedal is starting to show the same wear, but I usually unclip on the right side only, so that side is showing more wear. Adjusting the tension does not help, because the pedal body interface has lost too much material.
by alcatraz
Contact exustar directly or hunt a used/damaged set online for parts.
