It is currently Thu Dec 14, 2017 8:14 pm
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Sat Apr 22, 2017 5:00 am
Anyone else finding that properly set up Dura Ace 9100/9150 is louder than the older 9000?
It's only noticeable when in the 52/'big ring' and in the middle gears on the cassette. It is quiet in any cog on the cassette when in the small ring.
Due to it only happening in the big ring I think it might be due to the newer 'Shadow' rear derailleur which has more spring tension and I think is pulling the chain harder on to the cassette.
I'm using a Dura Ace 901 chain on an Ultegra cassette. I haven't tried a 900 chain but I am tempted to put the Dura Ace 9100 cassette back on and see if that is any different.
Anyone else experienced this or have tried any other options?
PostPosted: Sat Apr 22, 2017 6:10 am
Check if your wheel is mounted straight. And if your RD hanger is straight.
Its one of the typical problems when anyone describes something like that.
PostPosted: Sat Apr 22, 2017 9:01 am
Two 9100 bikas. It's louder.
PostPosted: Sat Apr 22, 2017 9:16 am
Someone should do a decibel test
Colnago C-59 (Dura Ace)
Firefly(Ultegra)
Trek 5200(ultegra)
PostPosted: Sat Apr 22, 2017 10:22 am
Riding on 9150, it does seem louder...
PostPosted: Sun Apr 23, 2017 12:08 am
I have 9070 Di2 and 9100 mechanical with identical gearing and chains. The 9100 is every bit as silent.
PostPosted: Sun Apr 23, 2017 5:50 am
I went from 9000 to 9100 and can't tell a difference.
PostPosted: Fri Jun 16, 2017 11:41 pm
I was also wondering about this. Don't know about 9000, but my 9100 is loud on the big ring, at least louder than my 7900 and 5800.
All my projects: http://photos.cybernck.com
PostPosted: Sat Jun 17, 2017 7:24 am
I've moved the derailleur back away from the cassette. It's a little slower shifting but quieter.
I've just replaced the chain at 3300km which is less k's than I used to get out of 9000 but I have done one or two wet rides so could be down to that.
PostPosted: Sat Jun 17, 2017 2:39 pm
LOL same issue. at first i thought it was a setup issue. the main issue is new derailleur design is very unforgiving with chains too long or short. i installed a new chain with length calculated with the big ring,big rear cog + 2 links. drivetrain is a lot quieter on the big ring. imho shimano took a step backward with the new design.
Current Rides:
2017 Giant TCR Advanced SL 0 DI2 9150
PostPosted: Wed Jun 28, 2017 10:39 am
PostPosted: Sun Aug 20, 2017 5:44 am
Yep I agree with this because the B-Screw makes a big difference to noise level also. Next time I put a chain on I'll remeasure it.
Are you on a M/L? Any idea how many links you have?
I like to have the B-Screw nice and close for fast shifting but it definitely runs quieter further away. I run my 9000 RD much closer.
I had a lot of inconsistent clicking, which I thought was also drive train related but turned out to be bits of carbon and plastic inside the rim. It must be from manufacture. Was very annoying to track down. I like the SLR wheels which come with the TCR but that's a mark agents them.
There are no new unread posts for this topic. Dura-Ace 9100/9150 and 10 speed
fosen
Sat Nov 18, 2017 4:23 am
egebhardt View the latest post
There are no new unread posts for this topic. Dura ace 9000 V 9100 brakes
scottmmw
Mon Oct 23, 2017 7:51 pm
evan326 View the latest post
There are no new unread posts for this topic. 9000 left arm on 9100 crankset??
Delorre
10
882
Wed Nov 01, 2017 3:26 pm
Philbar72 View the latest post
There are no new unread posts for this topic. Shimano DA 9000 vs 9100 crankset
Grimpeur
11
850
Mon Dec 11, 2017 11:12 pm
XCProMD View the latest post
There are no new unread posts for this topic. 9100 bar end shifters or 9000 cross compatibility
ultyguy
Thu Feb 16, 2017 11:05 pm
tokyodrift69 View the latest post
Users browsing this forum: antonioiglesius, beanbiken, Bing [Bot], Chris3g, IchDien, Imaking20, nobuseri, P90Puma and 38 guests
