It is currently Thu Dec 14, 2017 9:25 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Tue Apr 25, 2017 5:14 pm
The other thing to look at is the b-screw - could be the wrong angle causing that.
I'm left handed, if that matters.
PostPosted: Wed Apr 26, 2017 9:21 am
Definately something to look into.
Im a mtber and cant figure out really what happens when you adjust bscrew on this derailleur...
PostPosted: Sun May 07, 2017 9:26 pm
Okey so Ive ridden the bike one more time since last... Apparently the FD is pretty much spot on and there is a clicking / mechanical noise every once or twice every 360 crank movement. Thats the sound I thought was a bad derailleur setup I think. Didnt have tool to remove the SI crank arm, but noticed that I needed alot more force to undo and especially tighten the drive side center nut ( https://www.google.se/search?q=cannonda ... Bl2nnKzW0M: ) than 40nm as specified. It was really hard to remove and put back in there. 99% sure its correctly inserted. Doesnt look wrong or something. Just requires alot of force.
Need to buy tools and remove the crankset and have a look. I should have bought a specialized allez sprint locally than this caad12 from a very small company in spain. No customer support at all..
PostPosted: Sun May 07, 2017 9:34 pm
It's not the FD cable hitting the crank is it?
PostPosted: Mon May 08, 2017 8:06 am
No its not... But still. The bolt on the drive side needs alot more than 40nm. Something seems to be wrong...
PostPosted: Mon Jul 17, 2017 11:32 am
Well. I found the solution a while back to my noise...
It was a dry freehub body which made the rattle every pedal stroke. FML :|
There are no new unread posts for this topic. These Lightweight brakes?
PLuKE
7
1262
Mon Aug 07, 2017 8:42 pm
kulivontot View the latest post
There are no new unread posts for this topic. Lightweight Urgestaldt
Roadeeee
21
3258
Fri Feb 24, 2017 9:49 pm
KCookie View the latest post
There are no new unread posts for this topic. lightweight cockpit
Rubik
11
1837
Wed Apr 26, 2017 12:43 pm
DaReef View the latest post
There are no new unread posts for this topic. Lightweight meilenstein. 16/20 or 20/20?
TurboTommy
7
522
Mon Oct 30, 2017 7:47 pm
kgt View the latest post
There are no new unread posts for this topic. Lightweight Square Taper BB?
jfracer03
18
602
Thu Dec 07, 2017 3:02 pm
Geoff View the latest post
Users browsing this forum: Bing [Bot], Google Adsense [Bot], markyboy, silvalis, Squashednuts, Vermu and 34 guests
