It is currently Sun Dec 17, 2017 5:29 am
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Fri Apr 21, 2017 12:44 pm
Hello all,
I am riding relatively high-profile deep tubular carbon wheels with 40mm valve extensions, and was considering to start carrying sealant with me along with my spare tufo tubular and mini-pump. However I am wondering: Is it reasonable to believe that I can inject the sealant with just the valve removed and leaving the valve core extension in place?
Sorry if the answer to the question is obvious, I have had no flat with tubs so far, and never used sealant - so I have no experience what to expect, but it is still good to be prepared...
I think that having to unglue the tubular and remove the valve core extension in order to inject the sealant, would make the whole sealant carrying thing a moot point.
Thanks,
lightweenie
PostPosted: Fri Apr 21, 2017 1:33 pm
you can inject tufo extreme through an extender, no issue, just remove core, press nozzle in, squeeze
aside from sealant and valve core tool (supplied with the tufo), also carry a bit of plastic coated wire to poke in if the extender gets sealed - in a pinch you can use the tie wire that comes with the tufo to hold the core tool in the box, but ideally something stiffer
PostPosted: Fri Apr 21, 2017 1:40 pm
I inject Orange Seal through an extender all the time. I use it as a prophylactic.
PostPosted: Fri Apr 21, 2017 1:45 pm
Are you that worried about your tires getting pregnant?
PostPosted: Fri Apr 21, 2017 2:31 pm
Funny you have mentioned it, as before yesterday I was playing with the valve/valve extender clog.
There was no way to remove it using a long needle or a straight coated wire. What helped was a tiny loop on the end of the uncoated wire, which I span inside the valve. Few seconds and the clog was removed :)
Cervelo S5
Cervelo R5 VWD 5637g/12.43lb
Pronghorn XC SW Race 8284g/18.26lb
PostPosted: Fri Apr 21, 2017 11:52 pm
LOL. See number 2.
From Merriam-Webster:
Definition of prophylactic
: guarding from or preventing the spread or occurrence of disease or infection
: tending to prevent or ward off : preventive
There are no new unread posts for this topic. Grifo valve extension advice
alanmclean
Thu Oct 05, 2017 7:30 pm
alanmclean View the latest post
There are no new unread posts for this topic. Canyon H36 with Syncros Tri extension
dorin
12
1226
Fri Oct 20, 2017 1:52 pm
dorin View the latest post
There are no new unread posts for this topic. Attachment(s) PSA - B.O.R. German Sealant (UPDATE) - DO NOT BUY
possibleweenie
26
1909
Tue Nov 21, 2017 2:11 pm
eins4eins View the latest post
There are no new unread posts for this topic. Sealant/Wax for matte finish?
gceniza
26
2249
Fri Dec 15, 2017 1:10 pm
BikeAnon View the latest post
There are no new unread posts for this topic. Valve extender help
4ibanez
7
502
Sat Jul 01, 2017 6:29 pm
4ibanez View the latest post
Users browsing this forum: Bing [Bot], JS300, KLabs and 28 guests
