Park Stand - PRS-20
p3dalfaster
by p3dalfaster
Hi Guys,
Question, I am trying to put my PRS-20 together. Inside the Yoke Weldment, there is a plastic sheeth, this makes inserting the Slider Tube Weldment super super tight. Is this sheet supposed to be there, or is it purely some protection for carriage?
Thanks a lot!
BRM
by BRM
too cryptic for me :? , a picture do wonders . . .
btw for these kind of questions youtube often helps you
Butcher
by Butcher
It's been awhile since I put mine together, but I used the plastic sleeve. Is it absolutely needed? I do not know, but I followed the instructions and it works perfectly.
wobbly
by wobbly
from memory.....I recall this being a tight fit - I think some gentle "persuasion" and it slid in ok and all parts were absolutely needed. Have faith, hold your nerve and follow the instructions in the box :beerchug:
bikerjulio
by bikerjulio
lubricant
There's sometimes a buggy.
One.
p3dalfaster
by p3dalfaster
Cheers for the replies lads - I actually spoke with Park, they said it's needed but are going to send me another anyway "just in case" - good customer service from them. :thumbup:
goodboyr
by goodboyr
Just further on this. Make sure you grease inside and outside this sleeve before you install. If you use the stand to wash your bike, the centre steel support tube will rust. Since rust takes up more volume than plain steel, that will freeze everything up. I went to the prs21 which has an anodized aluminum shaft and it has been faultless after countless washes.
Sent from my SM-G900W8 using Tapatalk
