It is currently Fri Jan 19, 2018 5:13 am
Post new topic  Reply to topic  [ 216 posts ]  Go to page 1 2 3 4 515 Next
PostPosted: Sun Apr 16, 2017 5:28 pm
The new Shimano Powermeter gets looked at
https://youtu.be/okNpp5_E2-4
J EURO
PostPosted: Sun Apr 16, 2017 7:44 pm
Three things that disappoint:
- Cadence measured by magnet, not accelerometer.
- Claimed accuracy of +/-2%. Most other manufacturers are claiming +/-1.5% or even +/-1%. I know these numbers should be taken with a grain of salt but it is below what I would consider the industry standard. It will be interesting to see how the DA stacks up against others.
-Price for the power meter is an additional $1000. I was hoping they could come in quite a bit less given this is an OEM solution integrated into the crankset.
Generally Shimano puts out good product but for now I'm pretty underwhelmed by the power meter specs.
PostPosted: Sun Apr 16, 2017 9:51 pm
add to that list the "calibrate before every ride"
PostPosted: Mon Apr 17, 2017 4:10 am
Count me in the camp of not impressed. I do think it's a step in the right direction of further commoditizing power meters, but as is typical a pretty mediocre first attempt.
PostPosted: Mon Apr 17, 2017 11:15 am
This is a feature to be appreciated and not a bug to be disappointed by.
PostPosted: Mon Apr 17, 2017 12:36 pm
meh i prefer the auto-calibration of P2M or back pedal by Quarq.
PostPosted: Mon Apr 17, 2017 12:55 pm
I doubt cadence is measured by magnet. GCN may be pulling this out of their ass.
Note that Pioneer uses a magnet to establish a datum for power vectors. Not necessary for power measurement only.
PostPosted: Mon Apr 17, 2017 1:51 pm
Well it wouldn't be the only PM to require a magnet to measure cadence. The SRM powermeters work like this.
PostPosted: Mon Apr 17, 2017 2:19 pm
Yeah, I bet the magnet is to measure cadence. I had the chance to inspect this power meter first hand on the bike of a Sunweb-rider last week, and he had the same magnet. But I can't see why a magnet is a downside.
PostPosted: Mon Apr 17, 2017 2:47 pm
Online
Yeah, in which way does it matter that they use a magnet to measure cadence. The only downside is that it introduces an error with non round rings. Otherwise I'd actually prefer a magnet as it would be less sensitive to cobbles and rough roads where I sometimes have experienced wierd cadence readings from accelerometer based cadence sensors.
Pre ride calibration is also not a downside IMO, it gives the option for a very controlled calibration procedure.
PostPosted: Mon Apr 17, 2017 3:11 pm
Accelerometers are subject to the issues @Kurets just mentioned.
But on the topic of pre ride calibration, I do it every ride, but I'm not sure exactly what it does. I run SRM power meters with a Garmin 1000 head unit. The calibration is done from the Garmin. Sorry this question isn't specific to the Shimano power meter but more of a general question relating to all power meters. Thanks in advance.
Colnago C60 - PR99; C59 Five Years Later; My Special Colnago EPQ
Trek Emonda SL Campagnolo SR; Trek Koppenberg - Where Emonda and Domane Meet
PostPosted: Mon Apr 17, 2017 4:05 pm
The pre-ride calibration of a powermeter zeros the torque reading. The measured stress across the strain gauges will change minutely based upon the ambient temperature. Zeroing the PM accounts for this and ensures that all torque subsequently measured is due to the rider applying force to the pedal, and gives the rider a more accurate reading on the power they are producing.
PostPosted: Mon Apr 17, 2017 4:13 pm
On the Quarq do you backpedal before the ride? I always do the initial calibration from my Garmin 520. I wish there's a way to auto calibrate upon establishing the initial ANT+ connection. I'm always in a hurry to leave on a ride and I find it annoying to have to manually calibrate the ride by initiating a calibrate command from the Garmin. I would not think the backpedal calibration is accurate as the crank is not stationary.
PostPosted: Mon Apr 17, 2017 6:33 pm
Thanks @BdaGhisallo, I knew it accounted for changes in ambient temperature from one ride to the next, but I wasn't quite sure what it was actually doing. Your explanation helps clarify that for me.
:beerchug:
PostPosted: Mon Apr 17, 2017 8:03 pm
:beerchug:
My pleasure. This will add some more insight into the desirability of having to do the zero offset check before each session with a powermeter: https://powermetercity.com/2016/03/10/p ... ro-offset/
There are no new unread posts for this topic. Shimano Dura-Ace R9100 STI Lever bad clamp
uraqt
Tue Sep 19, 2017 3:02 am
uraqt View the latest post
There are no new unread posts for this topic. Shimano FC-R9100 crankset with 9070 Di2 front derailleur
Bigger Gear
Fri Jul 14, 2017 1:46 pm
ooo View the latest post
There are no new unread posts for this topic. Drag in BB-R9100 bottom bracket
savechief
7
1118
Wed Jun 14, 2017 11:20 pm
pdlpsher1 View the latest post
There are no new unread posts for this topic. Swapping R9100 chainset chainrings
lovemyway
Wed Jul 12, 2017 5:55 am
lovemyway View the latest post
There are no new unread posts for this topic. Ultegra R8000 or Dura Ace R9100 cassette
TonyM
14
1576
Tue Oct 24, 2017 2:15 am
MalibuCANE View the latest post
Users browsing this forum: Allen254, beanbiken, Bing [Bot], donald, Hapsmo911, KarlC, Noctiluxx, tokyoturtle and 24 guests
