It is currently Wed Oct 18, 2017 9:02 am
Post new topic  Reply to topic  [ 13 posts ]
 Post subject: Garmin Vector failure
PostPosted: Sat Apr 15, 2017 9:51 pm
Has this happened to anyone else? During a ride I got a message on my Edge 800 that it had lost contact with the right-side power meter. I thought the battery had died, but when I got home I saw this. It has less than 2K miles on it, and I haven't snagged it on anything or abused it in any way.
My favorite components are the ones I never have to think about.
PostPosted: Sun Apr 16, 2017 2:21 am
Did not snag that you know of?..I tagged a rock once in a paceline .. smacked my curb at my doorstep in a hurry..
Doesn't hurt to ask garmin.. they might send you one
PostPosted: Sun Apr 16, 2017 3:35 am
After doing this 3 times I sold them. Garmin vector - not fit for purpose
PostPosted: Sun Apr 16, 2017 8:13 pm
Have the vector 2 years never a problem
Sent from my HTC One_M8 using Tapatalk
PostPosted: Mon Apr 17, 2017 2:11 am
The v2 are more resilient then v1.. I've had vectors since release.. v1 was fairly easy to wreck ... but sometimes it's user error too.
PostPosted: Mon Apr 17, 2017 2:14 am
Have had them since they first came out, used everyday, swapped within 3 bikes, zero issues.
PostPosted: Mon Apr 17, 2017 6:57 am
Been using the v1 and upgraded to v2, which the pods are much better. Couldn't believe it breaks on its own.
PostPosted: Mon Apr 17, 2017 8:29 am
The most likely thing it snagged on that could possibly tear the plug off is the chain... I have two sets of Vectors and have been using them for three years with no problems
PostPosted: Mon Apr 17, 2017 2:04 pm
That's my kids favorite excuse 'I did not do it, it broke itself'.
Does not hurt to ask if Garmin will take care of it. I would look for signs of impact.
PostPosted: Mon Apr 17, 2017 7:47 pm
Worst case scenario a new pod is $80.
PostPosted: Tue Apr 18, 2017 4:03 am
What I found was that if you hit a bump that slapped the chain enough and it happened to coincide with the pod being in the right part of the pedal stroke then the chain would clear sheer the pod connector off. At $100 to replace it gets expensive.
PostPosted: Tue Apr 18, 2017 4:16 am
This happened to me once - it's the chain that caught the pod's plug on the inside of the pedal/crank arm. I had it when changing bikes and going from Shimano to Campag. It was hardly noticeable, but the plug stuck out just a fraction (less than a mm) further on the inside of the crank arm.
The solution is to put a washer on the drive side pedal which allows the plug to go further in on the other side - i.e. further away from the chain. Garmin will likely replace it without charge as the pods have been a continual problem for them (I had a couple of v1 pods brake for different reasons and they were very helpful each time). The pedals have been great for me overall.
PostPosted: Sun Aug 13, 2017 3:29 am
I'm still using the V1. Haven't had to replace or change the pods at all.
There are no new unread posts for this topic. Garmin Vector 2 Upgrade
Kurets
Mon Jan 23, 2017 5:30 pm
Kurets View the latest post
There are no new unread posts for this topic. Garmin Edge 1030 and Vector 3
[ Go to page: 1 2 3 4 5 ]
Tillquist
73
12682
Fri Sep 15, 2017 11:15 am
idinfo68 View the latest post
There are no new unread posts for this topic. Tried Garmin Vector 2's vs Quarq Dzero on the same ride
gurk700
11
1630
Wed Mar 08, 2017 10:17 pm
niklasp View the latest post
There are no new unread posts for this topic. Will using a cadence magnet in the crank arm interfere with Garmin Vector?
Kaboom
11
389
Wed Aug 09, 2017 8:50 am
Kaboom View the latest post
There are no new unread posts for this topic. Caad10 sub 7kg with Vector 2 Project
sgergole
Tue Feb 14, 2017 4:30 am
nemeseri View the latest post
Users browsing this forum: Baidu [Spider], petromyzon, Yahoo [Bot] and 29 guests
