It is currently Wed Jan 24, 2018 1:02 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Fri Apr 14, 2017 8:08 am
Hi guys i am looking at buying this frameset and need some help on what to build it with and can i run modern
equipment,like headset size etc etc.
I can build modern bikes no probs at all any help would be great thanks.
http://www.ebay.co.uk/itm/Colnago-Maste ... SwnF9Y6SgG
COLNAGO C60 SUPER RECORD EPS
Pinarello f8 sram etap
Eddy merckx 69 ultegra disc winter bike
PostPosted: Fri Apr 14, 2017 8:52 am
The ebay listing will tip you off on the headset right away - 1" threadless, external.
Some quick research on the newly produced Arabesque frames will fill in the other gaps.
You'll want to consider Campagnolo and on that frame an older grouppo may look more aesthetically approproate.
You may be able to source some 8, 9 or 10 speed grouppos at a good price.
Campagnolo 1" threadless external headsets are also still available in a high polish that would suit that build.
Consider sourcing some 26.0 bars and an older 26.0 stem (which you'll need for the fork steerer anyway / or use a 31.8 with a shim down to 26.0, but that might be too chunky for this build.)
A set of standard box rimmed wheels and you are good to go.
Keep this build classic. Trying to cobble carbon on there such as carbon bottle cages, will be disappointing.
PostPosted: Fri Apr 14, 2017 9:02 am
You can run all modern equipment on it if that's they way you want to go, I basically did that on my Master 30th. Campy still make 1" external headsets, so do CK I think. You'll need a shim to fill out the 1" steerer to fit a modern stem but other than that it's all the same as any other build.
PostPosted: Fri Apr 14, 2017 11:23 am
Purely subjectively - I find retro style quill stems look so much better on 'noodle' thin tube diameter steel frames. A modern ahead stem that is thicker than the frame tube looks out of place (to my tastes anyway)
FWIW I could nnot find a comfortable ergonomic handlebar in 26mm diameter so I had a quill stem custom made to take 31.6mm clamp bars.
I built my Colnago Master X Light with the aforementioned Campagnolo 1" threaded headset and because I insist upon compact cranks I compromised on period correctness and built my frame up with all silver Athena UT 11 speed. You can build with the all silver Campag gruppos as your frame will have Italian threaded BB for which Campag make appropriate BB cups.
PostPosted: Fri Apr 14, 2017 11:35 am
My "period correct" 2012 Master 30th anniversary build
PostPosted: Fri Apr 14, 2017 12:40 pm
Very nice indeed.
My questions are things like cutting the steerer and how does the headset fit if it's quill stem ? I am so up to date on new stuff
But not the old
Ps how does it ride compared to say a ti which I have and find really comfy and say a carbon frame
I have a c60
PostPosted: Fri Apr 14, 2017 3:18 pm
It's not a quill stem on that, there's a shim over the steerer that's 1/8" thick, so I could attach that -17 stem the usual way.
It rides really nicely, prefer the feel to my 2010 Cento Uno and it's stiffer than that frame. People stop and talk to you a lot when you ride it. It's just a touch heavy really, haven't built my C60 yet to compare the two.
There are no new unread posts for this topic. Colnago Arabesque
markyboy
11
1234
Tue Jan 02, 2018 9:10 pm
vejnemojnen View the latest post
There are no new unread posts for this topic. Colnago master pr82
markyboy
Wed Jan 17, 2018 8:32 pm
Js2 View the latest post
There are no new unread posts for this topic. Colnago Master frame size question
stam1668
Sun Jan 29, 2017 12:29 pm
kgt View the latest post
There are no new unread posts for this topic. Colnago C60 build sugesstions...
alexneumuller
10
904
Mon Oct 02, 2017 9:59 am
Boshk View the latest post
There are no new unread posts for this topic. what's going on with Colnago
fromtrektocolnago
Sun Sep 17, 2017 3:27 pm
joeyb1000 View the latest post
Users browsing this forum: di luca, Hennesy, PinaF8, rainerhq, siim, TurboKoo and 19 guests
