It is currently Sun Oct 22, 2017 4:44 pm
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Fri Apr 14, 2017 7:46 am
Hi
I've looked on the forum and it looks like you can run a campagnolo 10 speed cassette with 11 speed chain?
I'm currently using a super record rs front deraiĺleur and I am getting slight rub issues with a 10 speed chain due to the narrower cage. I'm certain the narrower chain will stop this. The front derailluer is set up spot on.
PostPosted: Fri Apr 14, 2017 8:35 am
Yes.
11 speed seems quieter also. Works 100%.
PostPosted: Fri Apr 14, 2017 9:24 am
Perfect - thanks!
PostPosted: Sat Apr 15, 2017 2:01 pm
Shop Owner / Manufacturer
By definition it can't be if you are mixing 11s with 10s - the near-0.5 mm difference in the chain width is definitely the problem.
Why an 11s FD? 10 would shift better and you'd not have the issues you have. 11s chains *can* ride the inner ring on downshift on 10s cranksets - success in use of this mix is variable with use conditions and frame geo / gear combination.
PostPosted: Sat Apr 15, 2017 5:00 pm
It must seemed odd I'm mixing and matching. I'm slowly upgrading to 11 speed. Just trying to wear our my 10 speed record shifters first. I'm a tight fisted weightweenie. :D
PostPosted: Sun Apr 16, 2017 1:10 am
Slowly upgrading is not a smart idea. Because of compatibility issues.
And a full group is cheaper than a collection of separate components.
There are no new unread posts for this topic. Campagnolo 11 speed crank w/ 9 speed chain Compatability
rgamble
Fri Oct 28, 2016 9:09 am
icenutter View the latest post
There are no new unread posts for this topic. Attachment(s) Adding 16T to 11-xx 11 speed cassette
efeballi
12
817
Sat Oct 07, 2017 10:10 pm
efeballi View the latest post
There are no new unread posts for this topic. Campagnolo 11 speed cassette lockring help
Sweetbabyj45
19
1015
Tue Jul 18, 2017 4:54 pm
Sweetbabyj45 View the latest post
There are no new unread posts for this topic. Attachment(s) SRAM or Shimano 11 speed cassette
DeLuz
33
2463
Wed May 03, 2017 12:59 pm
muntos View the latest post
There are no new unread posts for this topic. 11sp 11-30, 11-32, 12-32 cassette speed jumps comparison
ooo
23
2166
Sat Dec 31, 2016 10:57 pm
bm0p700f View the latest post
Users browsing this forum: audiojan, Baidu [Spider], Factory, leej88, lockxchg, TheKaiser and 33 guests
