It is currently Sat Jan 20, 2018 8:30 am
Post new topic  Reply to topic  [ 9 posts ]
 Post subject: Campagnolo Freehub help
PostPosted: Thu Apr 13, 2017 9:05 am
hi all
the freehub on my trusty old boras went recently they are from about 2005-2007
i ordered a replacement part fh-buu015 no r2107178 however it does not fit as its not completely round on the inside near the hub the old one is completely round so wont go over a lip that's on the axel
what part number should i be looking for?
thanks
john
PostPosted: Thu Apr 13, 2017 9:49 am
Your boras have the pre-2006 axle that will only accommodate pre-2006 cassette bodies.
Haven't seen those available for quite a while, second hand would be your best bet.
Find an old wheelset or hub for a donor.
PostPosted: Thu Apr 13, 2017 11:02 am
you need to change the spindle as well. see this:
{USERNAME} wrote:
Use in conjunction with HU9849 (FH-BO001) on hubs/wheels with non-cutout axles (equivalent of Campy # FH-RE415)
http://www.bikeman.com/FW9850.html
It's a straight swap http://www.bikeman.com/HU9849.html
There's sometimes a buggy.
One.
PostPosted: Thu Apr 13, 2017 11:51 am
thanks i will try and find a freehub first if not i will just get a new axel, will the new model axel be ok to use on the wheel?
PostPosted: Thu Apr 13, 2017 12:44 pm
Not done it personally, but the axle is supposed to be a straight swap for the old one.
Since it's been more than 10 years since the change, you could also look for a "donor" hub for an updated spindle.
One.
PostPosted: Thu Apr 13, 2017 5:56 pm
Most of the comments above are correct.
You have the first generation (round axle) freehub. You can find any Chorus/record donor hub on Ebay. If the hub is gen2 (3 flat spots on axle), then move both the freehub and the OS axle.
I assume your problem is brearings. Instructions on how to change them is here. http://forums.roadbikereview.com/campag ... 21207.html
Also, see PM
PostPosted: Thu Apr 13, 2017 10:08 pm
It is an easy swap for the new axle and free hub. I was in the same position and decided to switch rather than look for old parts.
PostPosted: Fri Apr 14, 2017 9:41 am
And just think of the 20 grams you'll save :)
(5 grams on the axle, 15 grams on the cassette body)
PostPosted: Thu Apr 20, 2017 2:13 pm
marco fan wrote:
hi all
thanks
john
why not just replace the bearings if this is the only parts that failed. that's pretty straight forward.
There are no new unread posts for this topic. Campagnolo Bora freehub grease
wedgie
Mon Nov 27, 2017 4:23 am
Mackers View the latest post
There are no new unread posts for this topic. Tune freehub
steelme
7
899
Wed Apr 12, 2017 9:51 pm
steelme View the latest post
There are no new unread posts for this topic. Sram XDR freehub
Sun Oct 22, 2017 2:20 am
jlok View the latest post
There are no new unread posts for this topic. Attachment(s) Campagnolo 11 speed using 34/50x11/36! Yes it can be done with PRE-2015 Athena LC Big Gears on Campagnolo 11 speed
colnagoaddict
16
1533
Mon Dec 18, 2017 8:49 pm
graeme_f_k View the latest post
There are no new unread posts for this topic. Powertap G3 Freehub Question
calumfindlay
Fri Aug 25, 2017 6:33 pm
calumfindlay View the latest post
Users browsing this forum: alcatraz, Bing [Bot], Google Adsense [Bot], iamalex, MagicShite, preludervtec, wobbly and 39 guests
cron
