Tune freehub
steelme
by steelme
I currently have a tune wheelset which i like to convert from shimano 10 speed to campagnolo 11 speed. Looking at the internet, i see that there are two freehub available. One is blue campagnolo freehub and thenother is red campagnolo freehub. I am not sure which one will fit my wheelset? Pls advice.
madcow
by madcow
The red version is for hubs where the axle has a 15mm OD, and the blue for the 17mm OD.
steelme
by steelme
madcow wrote:The red version is for hubs where the axle has a 15mm OD, and the blue for the 17mm OD.
Thank you. I will be ordering the red one then.
ms6073
by ms6073
Doesn't the answer depend on which rear hub? For example I was under the impression that the older Tune Mag 150 hub with the red 10-speed freehub could not be converted to 11-speed.
steelme
by steelme
ms6073 wrote:Doesn't the answer depend on which rear hub? For example I was under the impression that the older Tune Mag 150 hub with the red 10-speed freehub could not be converted to 11-speed.
Wouldn't the campagnolo freehub (red) accept 11 speed cassette? I want to make sure that it will work for my setup which is SR 11 speed groupset.
jih
by jih
Campag didn't change the freehub specs between 9/10/11 speeds, so yes, any campag compatible freehub body that isn't 8 speed (which is ancient now) will work.
Valbrona
by Valbrona
You been riding Shimano too long.
steelme
by steelme
I just ordered one from Starbike. Thanks
