New frame help - Canyon Aeroad BB?
joelpace
by joelpace
I'm building a Canyon Aeroad. I'm a life long Campy user, but I've decided to try SRAM Etap. I know nothing about SRAM. Here is my first question - I want to use a SRAM Red crank. But, what bottom bracket adapter do I use? The frame has a press fit BB86 bottom bracket. Help?
Attermann
by Attermann
you need a BB86 gxp bottom bracket.
1415chris
by 1415chris
Get yourself aluminium threaded together one, for instance wheels mfg bb86 for Sram 24/22 (gxp Sram Red crank version which will fit in your frame) with angular contact bearings.
drhex
by drhex
Used the sram bb86 gxp one works so far.
milesthedog
by milesthedog
Why the SRAM Red crank? it's a good price for what it is, but taking advantage of the bb386 could be pretty nice. I have both, but really prefer my THM M3....
MayhemSWE
by MayhemSWE
milesthedog wrote:but taking advantage of the bb386 could be pretty nice.
What BB386? To my knowledge all of Canyon's framesets have a BB86 aka vanilla PressFit bottom bracket shell.
Hexsense
by Hexsense
yeah, Canyon use BB86 which is 41mm diameter 86.5mm wide.
That design for plastic or metal cup 41->37mm bb shell and 37->24mm bearing in mind. So it best suite for Shimano Hollowtech II/Sram GXP 24mm axle.
BB386 is 30mm spindle diameter, 86.5mm wide
Apperantly there are bearings that pressed in bb86 bottom bracket directly (like Rotor 4130, 41mm outer 30mm inner: FSA, Enduro and WheelsMFG also have similar product) so the 30mm spindle of bb386 will fit. But i don't think that is ideal.
Attermann
by Attermann
Actually it works really well, I’m using a praxis chainset, has been running on my bad weather bike for almost two years, still running great
