It is currently Tue Dec 12, 2017 3:44 pm
Post new topic  Reply to topic  [ 1 post ]
PostPosted: Thu Apr 06, 2017 7:20 pm
Hi All,
I am considering swapping to the Extralite road stems, needing a 120mm. I can buy an older Road OC with the torx bolts used for $160 or a new Hyperstem from FWB for $210. Weight savings would be around 60 grams vs. my Easton EA90 stem which has been my go-to stem for years (stiff and reliable). Not sure how much of the weight delta could be made up with Ti stem bolts
The main difference I am seeing besides the interchangeable graphics on the hyperstem (not relevant to me since I am running a negative rise), is the angle choices on the Hyperstem. The OC is an 8 deg vs the hyperstem which comes in a 12 and 6. I currently run a 120mm -10 deg, and would probably choose the 12 deg as I my stack height is as low as it can be on my 2016 Evo Hi-Mod, but I could make the 8 deg work. (not a fan of the -17 look)
From the Fairwheel stem review, the Hyperstem is 6 grams lighter but also slightly less stiff, so for me that would be in favor of the OC.
I am a little concerned over the reports of bar slippage, but I don't do a ton of heavy pushing/pulling on the hoods when I ride and I imagine sprinting from the drops would not be as big a concern for slippage. Also it seems a lot of people seem to be ok as long as proper install is done with carbon paste.
Anything I am missing or any other thoughts / recommendations would be greatly appreciated.
Thanks,
Dimitri
My 2016 Evo Hi-Mod
viewtopic.php?f=10&t=141400
There are no new unread posts for this topic. Computer Mount for Extralite HyperStem
Xico
16
1433
Mon Jul 31, 2017 3:49 am
torob View the latest post
There are no new unread posts for this topic. Hyperstem clamp crimp still a problem?
nickf
Sat Jun 24, 2017 9:04 pm
wheelsONfire View the latest post
There are no new unread posts for this topic. Alloy road bar with a drop curve like the ENVE SES Aero Road Bar?
VTR1000SP2
11
1661
Wed Oct 04, 2017 4:08 pm
cwdzoot View the latest post
There are no new unread posts for this topic. Extralite vs Mcfk stem
jever98
11
955
Tue Oct 24, 2017 7:22 pm
bilwit View the latest post
There are no new unread posts for this topic. Stronglight CT2 52/36 vs Extralite MC2 52/36 - anyone comparred performance?
dereksmalls
Sat Mar 25, 2017 12:15 pm
KCookie View the latest post
Users browsing this forum: 310rider, FIJIGabe, Philbar72 and 38 guests
