My 3t Bars Toast?
sethjs
by sethjs
I found these lying around in my garage with a Zipp SL stem attached. Took the stem off and looks like the stem was over tightened and the carbon in the bar impacted some.
These safe to ride or they toast? I'd say that ledge you see is 1mm or less high.
Thanks!
abrown3mtg
by abrown3mtg
OUCH. I'll let others pipe in but that doesn't look good to me. I'm guessing they are shot. I'm sorry. My friend. It looks like an overzealous hand with an allen vs torque wrench did a number on those.
Kayrehn
by Kayrehn
With carbon parts you often can't be sure what the extent of the damage is, so if it looks bad, assume the worst. This was obviously crushed to some extent, don't risk it.
PSM
by PSM
All my 3T carbon bars ended up like that. Even after correkt Nm. It's crap. (Team and LTD.)
I use Deda 100 aluminum now days. Worth the extra 70 grams penalty.
wheelsONfire
by wheelsONfire
I agree with PSM. Both my 3T bars looks same. I have only used Team and torqued under max value. Still marks like this, not fully as deep though!
Bikes:
Ax Lightness Vial EVO D
Paduano Racing Fidia
Open *UP*
grumpier
by grumpier
Dave Koeffel aka SuperDave posts on SlowTwitch and he works for 3T. I would check with him. He has always been very helpful
sharkman
by sharkman
There is a reason pro's still refuse to use carbon bars. This bar might be ok but I wouldn't use it anymore
Verzonden vanaf mijn iPhone met Tapatalk
sethjs
by sethjs
Apparently this is quite the common problem on 3T Team Ergonova handlebars? Or at least, same happened to this guy and they were scanned and cut up. I also used a torque wrench and didn't exceed spec.
https://www.youtube.com/watch?v=HZwhHRazjK8
