Does anyone have turn by turn directions of Paris-Roubaix?
Have you tried searching Strava or ridewithgps.com?
Sent from my SM-G920V using Tapatalk
If you get the file onto ridewithgps (or it already is) the website will make up a turn/cue sheet for you.
make sure the file is a GPX one, and not TCX.
that should allow you to get turn by turn on your Garmin. you need to activate the turn by turn on the Garmin once its loaded in. i think its normally off if you haven't used it.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
Here is the route I would like to ride. Can someone help me get it on my Garmin 500 or get it into turn by turn written words?
https://ridewithgps.com/trips/13618461
What happened to you after you fell? - Steve Porino
"I got back up and started chasing" - Geraint Thomas
- jekyll man
Have you tried the "export" function on the RH side tabs?
Choose TCX file format.
A pop up should come up asking if you want to save/ download or whatever.
Save it to your PC.
Connect 500 to PC.
Using Windows explorer, copy said TCX file to the "new files" folder on your garmin.
Disconnect 500.
Go outside, and turn 500 on. Wait 5 minutes or so while it processes the file into a course.
Have a brew.
Go back to the training options on your 500, look under courses and it "should" be there.
Save it to your PC.
Connect 500 to PC.
Disconnect 500.
Have a brew.
Official cafe stop tester
The signage placed on lampposts etc will surely be gone but what will always remain are the painted directions on the road surface itself! Look out for yellow 'PR' with a directional arrow painted on the road.
Paul.
Paul.
If the grand tours are like classical music, kermesse racing is punkrock, Belgian style.
Colnago C50, Campag SR11
