It is currently Sun Oct 22, 2017 2:48 pm
Post new topic  Reply to topic  [ 15 posts ]
PostPosted: Mon Apr 03, 2017 12:30 pm
Hi
I just bought a park tool for pulling bearings on a Campagnolo Ultra Torque crank. CBP-3. Worked fine on NDS but won't fit on drive side.
Does anyone have any recommendations on a tool that does fit? This is a pre 2015 SRM crank as pictured below.
Bobo S&S Steel Bike - 7.5 kg
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
PostPosted: Mon Apr 03, 2017 12:49 pm
I used this on my power2max which looks very similar:
http://www.superstarcomponents.com/en/campagnolo-bearing-puller-set.htm
I did need to grind the arms down slightly to get them to fit behind the bearing, but it worked in the end
PostPosted: Mon Apr 03, 2017 3:00 pm
I just ground down the ends of the park puller until it fitted. Works perfectly.
Where are you based?
PostPosted: Mon Apr 03, 2017 3:06 pm
you may need to remove the SRM. the cover on the PM is too thick.
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Mon Apr 03, 2017 6:01 pm
Like @jbentley above, same solution, different name…
Super B TB-BP10 Campagnolo bearing puller and bearing installation set
The puller arms are held together with nuts/bolts, not rivets, so you can remove one arm and reassemble it in the recess around the bearing on the power meter. No need to grind down the tabs. It’s fiddly, but it works.
Also, good God man! Clean those chainrings before posting pictures like that. Think of the children! :wink:
Mom: He was very sickly until he started riding around on that bicycle.
Dad: Yeah... well... now his body’s fine, but his mind is gone.
PostPosted: Mon Apr 03, 2017 6:40 pm
Yes, think of the children! :)
Here's my tools for dealing with Campy BB bearings... from VAR. Probably overkill if you just want to remove them and replace them, but the bearing puller below (2nd from left) does fit nicely into the SRM recess and grabs the bearing from all around itself, not just 2 or 3 prongs. Pulls it off super smooth, and you could use it again if you want. If you just want to clean them up, it's not necessary to remove them however, so I'm assuming you're replacing. I've actually never had to replace a set of CULT bearings due to wear yet.
Colnago C60 - PR99
C59 Five Years Later
My Special Colnago EPQ
Trek Emonda SL Campagnolo SR
PostPosted: Mon Apr 03, 2017 7:03 pm
The very problem of high end, long-lived bearings like CULT is the resulting trade-off between tool price and frequency of use.
Simply file 2-3mm off each of the Park angled teeth, and it will work.
You can still reuse bearings afterwards.
PostPosted: Mon Apr 03, 2017 9:53 pm
Flash lighting very unforgiving but yes, terribly dirty.
Which leads to the issue perhaps. Nds was getting crunchy.
I tried a little oil and it does seem smoother. But still not smooth. So I think they may actually need replacement. I'm going to try cleaning them up and taking a photo. The spacing of the balls does appear to be out.
I wish I had been able find that campagnolo tool online. Any tips on where to buy it.
Though I think colnago wins. Wow!
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
PostPosted: Mon Apr 03, 2017 9:55 pm
Ok so not an official campagnolo thing but still, super b looks very nice.
Silly me wonders off looking for a new thing to buy. But Ghisallo has suggested using the park tool but ground down. Thank you! I am in Sydney Ghisallo.
I did have a look for that VAR tool. I'm not sure they offer it anymore. Weirdly they had a bearing puller for BB30 crank but not campag.
I will get onto the grinding business.
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
PostPosted: Mon Apr 03, 2017 10:25 pm
If it's just dirty, get some of this stuff and flush it out... like I did with all the packing grease that SRM stuffs into the CULT bearings... then a couple drops of light synthetic oil and you're good to go...
Before...
After flushing and blowing out with compressed air....
Unless I'm actually replacing them, I clean them out while attached to the crank.
Colnago C60 - PR99
PostPosted: Mon Apr 03, 2017 10:38 pm
Dude, even your calipers are above average. You’re making us all look bad. :D
@mrgray, sent you a PM re. where to find the Super B tool.
PostPosted: Mon Apr 03, 2017 10:53 pm
Well it's good my mechanical skills are above average, since that's the only reason the rest of the group waits for me (sometimes) at the top of hills.
I learned long ago that good quality tools makes working on bikes so much more enjoyable and productive.
Colnago C60 - PR99
PostPosted: Tue Apr 04, 2017 12:44 am
ok so i cleaned it up a bit (bearing not crank).
without any oil in it, i actually had it free spinning. now with a tiny drop of that fancy oil NFS, it is not spinning much anymore but i presume thats irrelevant. so it seems fine and everything and all balls are there in the spacer but every now and then it sticks on something. not all consistent.
i might mount it back up, put the crank back on the training bike and see how i go but god it is a greasy shit show and so on the other hand i might just put a new bearing on.
cranks might have done several thousand km's on kickr bike and might have done 15000 prior to me getting them (based on state of crank itself). so who knows, maybe they do need changing.
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
PostPosted: Tue Apr 04, 2017 7:28 am
You couldn't find it because it's camouflaged as DR-10100 Fork crown race extractor :D
"- also suitable for removing Campagnolo and Fulcrum Ultra Torque and Power Torque crankset cartridge bearings"
PostPosted: Tue Apr 04, 2017 9:37 am
thanks! now found it available for sale. it is quite pricey. i think i'll grind down the park tool but no doubt it looks a lovely piece of kit.
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
There are no new unread posts for this topic. Campagnolo H11 - with regular crank?
bananapls
Tue Sep 26, 2017 10:52 am
Miller View the latest post
There are no new unread posts for this topic. How To Fit A Campagnolo Ultra Torque Crank To Cannondale PF30a BB
JayTheCyclist
7
824
Sat Apr 22, 2017 10:44 pm
stormur View the latest post
There are no new unread posts for this topic. New Stages Pwoermeter for Campagnolo Super Record...crank arm question.
kode54
Fri Mar 17, 2017 4:26 pm
AZK View the latest post
There are no new unread posts for this topic. Campagnolo 11 speed crank w/ 9 speed chain Compatability
rgamble
Fri Oct 28, 2016 9:09 am
icenutter View the latest post
There are no new unread posts for this topic. 130 BCD crank w/ 52/36 chainrings?
jbaillie
9
1312
Sat Jan 28, 2017 3:35 pm
mythical View the latest post
Users browsing this forum: Baidu [Spider], Google Adsense [Bot], jwfinesse, RedbullFiXX, sungod, themidge, Vallinotti, warx, wheelbuilder and 29 guests
