It is currently Sun Dec 17, 2017 1:43 am
Post new topic  Reply to topic  [ 6 posts ]
 Post subject: Project WW Emonda SLR
PostPosted: Fri Mar 31, 2017 3:40 pm
Putting a build together I'd like WW's input.
Published Google docs spreadsheet that's much easier to read can be found -->HERE <--
Weights listed are estimated with values found online. After I get some input from you guys on improvements, I'll be posting a final parts list. I'll document the build process with pictures and provide actual weight values on all the equipment being used.
Project WW Color Grams Price
Frame Trek Emonda SLR H1 54cm 690 $0 https://www.trekbikes.com/us/en_US/bike ... 9100-2017/
Fork Trek Emonda SLR cut 292 $0
Headset top Cane Creek / aer AERIS41 top 23.2 $60 https://www.canecreek.com/products/headsets/aer
Headset bottom Cane Creek / aer AERIS52 bottom 27.5 $46 https://www.canecreek.com/products/headsets/aer
Top nut eeNut Preload Assembly 9.7 $60 https://www.canecreek.com/products/head ... d-assembly
Spacers/Topcap Aer spacers 5mm and 10mm 5.7 $19
Stem MCFK 110mm 91.8 $344 https://fairwheelbikes.com/mcfk-carbon-stem/ http://www.mcfk.de/en/products/stem/stem.html
MCFK Stem Hardware Kit Red $35 https://fairwheelbikes.com/mcfk-carbon- ... dware-kit/
Bars Mcfk 44cm 179.1 $375.00
Tape Deda Elementi 23 $13 https://www.amazon.com/Deda-Elementi-HD ... B003UW6A2W
Bar Ends Deda Elementi 5 $0 https://www.amazon.com/Deda-Elementi-HD ... B003UW6A2W
Shifters SRAM RED 293 $0 Owned
Cables Brake Alligator I-links Red 60 $60 https://fairwheelbikes.com/alligator-i- ... cable-kit/
Cable Powercordz Red 10 $42 https://fairwheelbikes.com/power-cordz-brake-cable-set/
Cables/shift Alligator I-links Red 50 $70 https://fairwheelbikes.com/alligator-mi ... cable-kit/
FR Der SRAM RED 70 $0 Owned
Rear Der SRAM RED 143 $0 Owned
Brakes Front EECycleworks DM Front 79.4 $315 https://www.canecreek.com/store/brakes-levers/eebrakes
Brakes Rear EECycleworks DM Front 79.7 $315 https://www.canecreek.com/store/brakes-levers/eebrakes
Pads Included with rims 36.3 $0 https://reynoldscycling.com/shop/index. ... p_item=725
Crankset SRAM RED Quarq dzero Estimated W 637 $1,079 https://www.quarq.com/product/sram-red- ... r-chassis/
Chain Rings Praxis buzz 52/36 133.4 $150
BB HSC Ceramic for BB90 for Gxp 48.6 $120 https://fairwheelbikes.com/hsc-bb90-95- ... m-bracket/
Pedals Xpresso 15 155 $295 https://www.merlincycles.com/time-xpres ... 76305.html
Chain Kmc X11SL Silver 243 $65.00 https://fairwheelbikes.com/kmc-x11sl-chain/ http://kmcchain.us/chain/x11sl-ti-nitride/
Cassete SRAM RED 11-25 150 $161.95 http://www.planetcyclery.com/sram-red-2 ... wAodlpcPYw
Saddle Selle italia SLR Tekno Flow 95 $0 Owned
Mast Cap Bontrager Ride Tuned Carbon seatmast cap 130 Maybe some Ti bolts?
Wheels FSE Rim, CxRay Spokes, Carbon ti Hub Red 990 $1,385 FSE Tubular Rim 25mm, Carbon ti hubs Sapim CxRay Spokes
Skewers Extralite Steeters 29.8 $135 https://fairwheelbikes.com/extralite-st ... d-skewers/
Tires Schwalbe Pro One 700x24 560 $250
Tire glue Miyata tubular tape 16 $22.00
Cages Carbonworks set 10 $0.00 Owned
Fairy dust 20
5386.2 $5,417
S-Works Venge 54cm 7245.62
Etap & Quarq DZero
PostPosted: Fri Mar 31, 2017 4:49 pm
That is going to be one BA bike! Nice work, can't wait to see a pic.
2015 Storck Scenero G3, Force 22, Ultegra wheels, Zipp AL bars, stem, post
PostPosted: Fri Mar 31, 2017 8:02 pm
Thanks! I'm thinking about sanding down the Emonda frame and fork as it will be coming in Battleship w/e primer looking color to save even more weight.
Etap & Quarq DZero
PostPosted: Fri Mar 31, 2017 9:40 pm
Will that not invalidate the Trek warranty?
PostPosted: Fri Mar 31, 2017 11:53 pm
Valid point. I'm getting it through a dealer at cost so I need to make sure I'm getting a warranty with it.
"Every new Trek bicycle comes with our industry's best warranty and loyalty program - Trek Care. Once your Trek Bicycle is registered the Trek Bicycle Corporation provides each original retail purchaser of a Trek bicycle a warranty against defects in materials and workmanship, as stated below:"
If it comes with a warranty then I wont be sanding it down.
Etap & Quarq DZero
PostPosted: Sat Apr 01, 2017 10:41 am
The Battleship Grey colour is lovely, look good with everything else black.
There are no new unread posts for this topic. 2018 Emonda SLR vs SL
ClydesdaleChris
9
1805
Thu Oct 12, 2017 2:28 am
ClydesdaleChris View the latest post
There are no new unread posts for this topic. Emonda Alr Sizing
luxmediarts
7
704
Sun Nov 05, 2017 2:33 pm
luxmediarts View the latest post
There are no new unread posts for this topic. Low stack top cap for Trek Emonda
Geordiepaul
9
858
Tue Dec 05, 2017 5:44 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. Attachment(s) Cracked Brand New Emonda :-(
Geordiepaul
19
2610
Sat Aug 12, 2017 9:30 pm
There are no new unread posts for this topic. Attachment(s) Trek Émonda 2018
[ Go to page: 111 12 13 14 15 ]
hlvd
211
34327
Fri Nov 03, 2017 10:11 pm
ddsg View the latest post
Users browsing this forum: Bing [Bot], Catagory6, raggi, sib and 30 guests
