Finally have 99% of the parts for my new Supersix (2015 HM/58cm) and was setting it all up last night when I came to page 10 of the front deraillieur setup.
( http://si.shimano.com/pdfs/dm/DM-FD0002-05-ENG.pdf )
There is a tool mentioned (TL-FD90) to decide whether to use the converter:on or converter:off position.
This determines the FD cable angle.
I bought the DA parts from Merlin in one of their 'brown box' deals - I think it has minimal packaging etc. Anyway, I've looked for the plastic alignment tool to determine whether to have the converter on or off but I can't find it.
Can anyone help me out?
Anyone with a 2015 Supersix Evo HM? What FD converter position did you use? On or off?
It's DA9000.
Dura Ace FD converter:on or off position for Supersix?
- Contact:
You don't need the tool. Just eyeball it when you have it installed and take your best guess. If you pick the wrong setting, your FD won't shift smoothly/properly and you'll know to swap it.
Try the ON position first.
The converter design is flawed anyway. I have experimented extensively with it. On my Cannondale Supersix (non evo) i get much better FD trim and shifting by ignoring Shimano's converter tab completely and passing the cable straight over the top of the bolt instead. I get better leverage and the lever requires less force. Make of that what you will.
