Storck Aernario Platinum vs Colnago C60 vs Bianchi Speciallissima
by Fixie82
I see - apologies I thought when you were using the term Aero bike you were referring to design choices that minimise drag. What you are referring to I would call race geometry. Yes the Aernario is long and low with shorter hradtube sizes than others. It's also one reason to make sure your current fit, or potential fit, will work with the frame.
I can ride a 55 or a 57. I am lucky in the my fit can be replicated on a slammed 57 allowing me to take advantage of the larger tubes to gain an increase in stiffness. If I wanted to go lower I would need a 55 but would most likely run some spacers under the stem.
