I'm running a 2011 Campy SR UT crankset, and I am unsure if their newer 4 arm cranks are compatible with my current BB? I assume that the Ultra Torque on the newer 4 arm cranks are the same?
Also curious if the chainrings present and shifting issues with my older gruppo?
Thanks
Campagnolo Ultra torque advise
UT is UT the new cranks will fit and work perfectly
more information
Galleries:
› Skunkworks #2 Colnago C60› Skunkworks #1
› Skunkworks #3 Colnago C59
› Skunkworks #5 Speedvagen
› Skunkworks #7 NeilPryde
› Skunkworks #8
› Skunkworks #4 Speedvagen
› Skunkworks #6
- Shop Owner / Manufacturer
- Contact:
Kupepe wrote:2011-2014 groupsets are not compatible with 2015 onwards groupsets according to Campy.
Incorrect, though a widely-held misconception.
2014 and previous shifters and 2015 and later CH, RE and SR derailleurs are not compatible, all other parts will work at least as well together as the oldest component in the combination. You just won't get the full advantage of the full system ... although in fact a 2015+ crankset with a 2014- FD should work slightly better than the previous model as the big chainring has increased lateral rigidity by comparison to the 5-arm crankset.
- Similar Topics
- Replies
- Views
- Last post
- 2 Replies
- 522 Views
Last post by Valbrona
Mon Oct 09, 2017 5:06 am
- 32 Replies
- 2477 Views
Last post by winkybiker
Sun Oct 15, 2017 5:44 pm
- 2 Replies
- 514 Views
Last post by tommasini
Sun Oct 29, 2017 7:49 pm
- 16 Replies
- 1354 Views
Last post by AJS914
Tue Jul 25, 2017 3:24 pm
- 15 Replies
- 1402 Views
Last post by Calnago
Mon Jul 24, 2017 11:35 pm
