It is currently Fri Jan 19, 2018 11:13 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
PostPosted: Mon Mar 27, 2017 2:00 pm
Dear all,
I'm in a utter quandary over purchasing my first power meter. I have a couple of bikes with different standards (BB30 with SiSL2/ BB86 with SRAM Force Crank/ Threaded with Rotor 3D+.
As a general compromise I was looking at either upgrading my Force Crank with a P2M, or buying a new Quarq DZero Crankset... or I go down the 'it fits in everything but only measures one leg' route with the InPower...
The main question I have at this point is whether a Quarq DZero Red crankset would be demonstrably better than a Force Crankset with P2M spider. Would the Red crankset be stiffer at all?
An upgrade to my 3D+ with InPower would be the easiest option, but the internets say it is an inferior option to Quarq, P2M, etc....
Any advice at all....?
PostPosted: Mon Mar 27, 2017 10:16 pm
So why not just get the P2M Rotor 3D+ spider, which is compatible with both BB30, BB86, and 68mm threaded BSA with the appropriate BB?
PostPosted: Mon Mar 27, 2017 11:33 pm
P2M Rotor 3D+ will only fit with some (of dubious reputation) 30mm BB86 bearings.
The weight difference between converting your force->p2max and the rotor3D24P2M is negligible.
I would vote ForceP2M. p2m is great whatever crank you choose.
PostPosted: Tue Mar 28, 2017 5:48 pm
To clarify... You are saying the quarq red crank would be no better than a force p2max?
Thanks!
Sent from my 6039Y using Tapatalk
PostPosted: Tue Mar 28, 2017 6:23 pm
no i mean Force P2Max VS Rotor24P3Max
... my calculation might be off but based on mine (Rotor24) the Force would be very close in terms of weight.
Considering you already have a Force crank, fitting a P2M is *almost* a no brainer.
The new Quarq might be better that the old Quarq, but "issues" are fairly commonly reported online.
PostPosted: Tue Mar 28, 2017 7:57 pm
So three bikes and they all need power.
2 are 30mm, 1 is 24mm.
And you don't want to go crankarm or pedal?
The crankset takes 20 minutes to swap out, but don't think you'll be swapping spiders all that often. The lockrings aren't made for that frequent of changes.
I'd change the BB86 to BB30 and pick your favorite crankset.
PostPosted: Wed Mar 29, 2017 9:48 pm
Yeah it's abit of a toss up between the quarq and p2m spider to upgrade my force chainset right now!
PostPosted: Wed Mar 29, 2017 9:49 pm
buy an old S-type p2max spider. great price
PostPosted: Thu Mar 30, 2017 1:06 am
SRAM Red DZero GXP fits in virtually everything with the proper BB or adaptors.
PostPosted: Fri Mar 31, 2017 5:32 pm
Thanks everyone - I'm going for a Red DZero GXP!
:-D
PostPosted: Fri Mar 31, 2017 6:26 pm
Aaaaaaand now I'm weighing up chainring options. Looking at non-sram options, does anyone know if the OctaRamp MC or CT2s play well with SRAM Red 22 cranks?
Cheers
PostPosted: Sat Apr 01, 2017 5:18 am
Cheers
I'm using it but since red22 got hidden bolt on the crank arm, the drop chain pin not alight with the arm.
Sent from my SM-N9208 using Tapatalk
PostPosted: Sat Apr 01, 2017 6:59 am
[/quote]
[/quote]
Hi there, which chainrings? Does it mater they are not aligned, and how are they performing!
PostPosted: Sat Apr 01, 2017 7:37 am
I have CT2 on my Sram Red Quarq, work perfectly, just moved to fibre lytes with eTap, which are not quite as good.
Scott CR1 - 12.56Ib
Neon - 15.49Ib
PostPosted: Sat Apr 01, 2017 10:37 am
Cheers - and they look damn good on your Scott.
There are no new unread posts for this topic. Rotor InPower connecting but not transmitting
iamalex
Tue Jun 13, 2017 4:32 pm
NickKanwetz View the latest post
There are no new unread posts for this topic. Quarq dzero bb
visse89
Tue Jan 09, 2018 6:47 pm
dudemanppl View the latest post
There are no new unread posts for this topic. Quarq DZero Carbon vs Red
Hapsmo911
13
585
Tue Jan 09, 2018 2:22 am
jlok View the latest post
There are no new unread posts for this topic. Quarq DZero PM question
addictR1
11
656
Tue Nov 14, 2017 3:54 am
TobinHatesYou View the latest post
There are no new unread posts for this topic. Cutting q-rings to fit quarq dzero?
dairic
Sun Sep 10, 2017 7:20 pm
Users browsing this forum: Baidu [Spider], Shrike, ymisyd and 27 guests
