It is currently Sun Jan 21, 2018 8:10 am
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Sun Mar 26, 2017 4:23 pm
https://www.dtswiss.com/Components/RWS/ ... bolt-front
I currently run a Mavic Aksium disc brake front wheel. I believe this is 15mm thru-axle, but I use it with Mavic adapters to convert to regular quick release.
The DT Thru-Bolt is stated as 9mm, so I am guessing that it will not work with my hub, perhaps only with DT hubs.
Any other similar solutions out there?
Thanks.
PostPosted: Sun Mar 26, 2017 5:00 pm
DT make endcaps for their hubs to switch to thrubolt 9mm (front) and 10mm (rear).
they are essentially an "axle" style skewer for QR dropouts
* i believe other MTB hubs (Hope?) also can provide 9x100 and 10x135 endcaps
they allegedly stiff things up, particularly the front end. I like them.
PostPosted: Mon Mar 27, 2017 1:57 am
There are other hubs that offer endcaps for these too. My I9s (Torch Road Disc) have this option as well as some Bitex hubs I have. I've got a set of those DT skewers, as well as a set from Novatec that are a more traditional style but still 9mm and 10mm thru bolt. The Novatecs have a steel shaft and are STIFF if that's what you're looking for. I use them on my offroad only disc wheelset. The RWS set it on the road use wheels.
PostPosted: Mon Mar 27, 2017 2:28 am
Thanks folks.
I have a pair of end caps coming to convert my Mavic front hub from 15mm TA to 9mm TA.
Just seems a little disconcerting that the front dropouts should be resting on what is in effect a 9mm aluminium skewer. The existing system with a regular 5mm steel QR skewer would seem safer, as the dropouts are resting on the machined protrusions of the end caps.
There are no new unread posts for this topic. Giro Republic : Using 2-Bolt Cleat Mount with 3-Bolt cleats
gerryc89
Fri Jul 28, 2017 3:24 pm
TheKaiser View the latest post
There are no new unread posts for this topic. Attachment(s) Question about sram hidden bolt/non hidden bolt
Chans1ee
Thu Jan 04, 2018 8:42 am
Chans1ee View the latest post
There are no new unread posts for this topic. Felt ar bolt questions!
FredrikE
Fri Apr 14, 2017 8:10 pm
FredrikE View the latest post
There are no new unread posts for this topic. Red 22 ( 2016) b-bolt issue (?)
stormur
Wed Sep 27, 2017 6:15 pm
stormur View the latest post
There are no new unread posts for this topic. B.O.R Chainrings 4 bolt Shimano
itsacarr
Tue May 23, 2017 11:22 pm
itsacarr View the latest post
Users browsing this forum: No registered users and 37 guests
cron
