Power meter caad12 105 2017?
niklasp
by niklasp
Hi!
Exactly which power meter fits on a more professional less stock caad12 105 2017? It's bb30a and I'm very confused right now.
Chain set: Cannondale Si, BB30a, FSA rings, 52/36
Quarq something sounds good. Can I still use stock chain rings?
How do I know what fits bb30a? It seems it's like bb30 but 5mm wider?
Thanks in advance. The easiest way would be garmin vectors but they seem to be unreliable.
jlok
by jlok
safe bet would be the below?
Convert BB30a to GXP by using this [http://wheelsmfg.com/bottom-brackets/cannondale-bb30a/bb30a-adapters/bb-pf30-universal-adapter-for-22-24mm-spindle-cranks-sram-truvativ.html].
Buy Quarq DZero (non-hidden bolt, BCD according to your existing chainrings) [https://www.quarq.com/product/quarq-dzero-carbon-power-meter-chassis/].
Vector 2 latest firmware is ok. Sold mine and swapped to DZero as I want to use touring shoes with SPD pedals...
btw, just my 2 cents, dun sue me if anything goes wrong.
nemeseri
by nemeseri
Pioneer left side only is one option. Obviously you can keep your right side setup: http://www.pioneerelectronics.com/PUSA/ ... /SGY-PMLTC
The other option would be the power 2 max Type S or NG with praxis / sram chainrings. I'd love to hear experiences with this setup. SRM is also there with the classic praxis / sram chainrings.
grover
by grover
Lots of options.
Stages or 4iiii non-drive side hollowgram arm
BB30 Quarq - comes with a 5mm spacer on the non-drive side. Remove it and you install perfectly on BB30a
GXP Quarq - use conversion kit listed above
SRM/power2max/quarq spider for Hollowgram cranks
All of those options would allow use of your current chainrings. If ordering a spider solution just make sure you order 110bcd not 130bcd. If ordering quarq make sure it is the non-hidden bolt variant so your FSA rings chain drop pin actually lines up with the crank arm.
Sam
by Sam
bbinfinite makes "DirectFit" adapters. Expensive but seem straightforward.
evan326
by evan326
4iiii states that they can't be put on 16' and 17' hollowgram si arms. They don't say why, even though sisl2 arms are on the compatibility list. They have the same inner profle, so I don't see why they can't do it.
Stock FSA rings don't fit on the p2max, so you would have to get new rings.
niklasp
by niklasp
Well thanks alot.
Quarq seems like good stuff and as you say the bb30 variant fits bb30a (I emailed the support and asked).
Found quarq dzero 110bcd for 700 euro (carbon) and 600 euro (alu). Best price I've seen so far!
"The BB30 spindled power meters will work with the BB30A frame.  Unfortunately, we will not have a power meter that works with the Cannondale crank arms.  As for the chain rings, you will want to check the chain rings and make sure that they do not have a recess where they meet the spider.  You can use them with our 110 BCD power meters as long as they do not have that recess.  I attached an image that shows the recess."
jlok
by jlok
700EUR is for the PM itself or complete with crank sans chainrings?
Sam
by Sam
Starbike has the Quarq Dzero Carbon for €756 excluding the WW discount. That's the cheapest I've seen. And the reason why I just ordered it from them. :-)
