It is currently Tue Jan 23, 2018 9:23 am
PostPosted: Thu Mar 16, 2017 10:27 pm
I'm finding it hard to make a final decision as my knowledge on the subject is incomplete so hopefully you guys can help me.
Power2max NG, s-works comaptible or powertap p1 pedals. They won't be being moved from one bike to another generally. But if I choose to sell the frame in the future isn't it a little short sighted to get a power meter I can't transfer to a different frame? Seems it's probably also hard to shift on second hand vs more universal pedals. I have a few wheel sets I use so hub based pm is not really an option.
The power2max has the weight advantage, is it also more durable? I have no experience of either system with regards software etc either. I feel like logically with the info I have I should be picking the pedals but I still find myself leaning towards the power2max... and I don't have the info to make an informed decision. I'm new to the world of powermeters as this post probably makes painfully obvious! Can you guys help show me the obvious stuff I'm probably missing.
PostPosted: Thu Mar 16, 2017 11:03 pm
I can only speak for Power2Max but I have had no issues with the four (1 classic and 3 Type S) units I've owned over the last few years. I only bought one new, the other 3 were from eBay or forums, all have worked great, plus they're easy to use, no calibration needed before a ride so no worries of forgetting to zero out unit every ride. I wouldn't use any other as none seem as "set and forget" as P2M
PostPosted: Thu Mar 16, 2017 11:37 pm
broke 2 sets of p1. p2m still going strong. rock solid. no calibration. set and forget +++
PostPosted: Fri Mar 17, 2017 2:23 am
I always calibrate my p2m (through my garmin) before every ride and again 10-30 minutes down the road, before I start intervals or set off with a group. Is it REALLY unnecessary?
PostPosted: Fri Mar 17, 2017 7:12 am
I think the power2max calibrates itself as soon as the cadence is 0 for 15 or 30 sec
PostPosted: Fri Mar 17, 2017 11:18 am
Power2max every time. Mine has been absolutely rock solid. The only slight gripe I have with them is how quickly my type s responds to changes in power or cadence, it's slightly slower than my vectors. But I believe the new NG version addresses that.
PostPosted: Fri Mar 17, 2017 12:55 pm
"Anytime you stop pedaling long enough (approximately 3 seconds or more) power2max updates the zero offset"
https://www.power2max.de/europe/en/support/faq/
agree, it's very slight. will be interested if NG is better, i always assumed it had more to do with Ant+ being a once per second signal
PostPosted: Fri Mar 17, 2017 7:55 pm
Thanks for your input guys. Definitely food for thought.
There are no new unread posts for this topic. Powertap P1 Pedals
mattCSUK
Fri Feb 24, 2017 5:41 pm
Butcher View the latest post
There are no new unread posts for this topic. best gps unit for power2max
dedobike
18
1276
Fri Nov 10, 2017 6:59 am
TonyM View the latest post
There are no new unread posts for this topic. power2Max meters choices??
Boshk
12
1790
Fri Aug 25, 2017 9:59 am
Boshk View the latest post
There are no new unread posts for this topic. power2max power meter
bikeracer99
35
3743
Thu Mar 30, 2017 6:12 am
PinaF8 View the latest post
There are no new unread posts for this topic. Power2max vs Pioneer Ultegra
JBeauBikes2
9
1042
Wed Aug 30, 2017 9:22 am
RJKflyer View the latest post
Users browsing this forum: Baidu [Spider], Conza, jlok, MattN, vladi78 and 30 guests
