It is currently Sun Apr 30, 2017 12:36 pm
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Wed Mar 15, 2017 1:37 pm
i have an older 5-arm Campy Super Record Ti mid-compact crank. I see that Stages came out with the Campy crank PM.
question is...will that ND crank arm match or work with the older 11SR?
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 tubeless with carbon hubs
- Parlee Altum + DA9070 + Enve SES 4.5 carbon hubs
- Parlee ESX + DA9070 + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Wed Mar 15, 2017 2:20 pm
In for an answer because I also want one but have older 5 arm campy cranksets =)
PostPosted: Thu Mar 16, 2017 1:32 pm
It's still an "Ultra Torque(TM)" axle (see the Campagnolo docs), so it should work (i.e., fit together).
However, you have a Ti axle: is the Stages using Ti too? I cannot find that info on their webpage.
BTW: have you contacted Stages?
PostPosted: Thu Mar 16, 2017 3:10 pm
i contacted by email. they just responded after you posted. they didn't do any testing on previous versions...only the new 4-arm one.
i think there's no Ti version...yet. arm shape is slightly different.
PostPosted: Fri Mar 17, 2017 5:15 am
The left crank arm is going to fit fine. The graphics and shape of the 2014 Super Record left crank arm is slightly different than the 2015 crank arm. The internal splines on the axle are the same, though. I believe they are both Ti axles.
It's all downhill from here, except for the uphills.
PostPosted: Fri Mar 17, 2017 4:26 pm
Make sure the stages is a Ti Crank as the thread is also reverse threaded on SR.
'The bolt is reverse threaded so that it can't be used with the standard steel axles, because a chemical reaction between the Ti and steel could cause it to seize '
Please keep us posted, considering the same option if its a proper SR half shaft left arm crank.
There are no new unread posts for this topic. Campagnolo Super Record Rear Derailleur. 32t?
Ultimatek
Tue Aug 16, 2016 1:39 pm
graeme_f_k View the latest post
There are no new unread posts for this topic. Sram red 22 VS Campagnolo Super Record VS Shimano 9100
Look595
Fri Mar 17, 2017 6:09 pm
AZK View the latest post
There are no new unread posts for this topic. Shifting from small to big chainring on 2015 Campagnolo Super Record
ctn
9
432
Wed Mar 15, 2017 6:00 pm
Calnago View the latest post
There are no new unread posts for this topic. Stages Power meter for Campagnolo
icenutter
16
1913
Thu Oct 20, 2016 2:28 pm
metabo View the latest post
There are no new unread posts for this topic. Using Dura ace stages on tiagra crank
scottmmw
Sun Nov 27, 2016 4:24 pm
Multebear View the latest post
Users browsing this forum: Bing [Bot], HammerTime2, Oldfaithful and 31 guests
