Caad12 help
raffit78
by raffit78
In the process of building a 2016 caad12.
Ordered a 4iiii power meter. In which I would ship my left crank and they would install it on the arm and send the unit back.
Unfortunately, they do not have a sisl2 caad12 template and are asking for some images and some samples.
My bike is not together yet and unfortunately I can't provide them with this info. I'm hoping someone here might be able to help me.
They want an image of a AAA battery in between the left crank and the frameset to see where or if the battery would touch the frameset. And they want pictures. Here's there description in detail. If anyone can help, I would certainly appreciate it.
evan326
by evan326
I have a garmin cadence sensor on my Si arms that is about the same size as that. I will try to snap you a few shots
evan326
by evan326
Try these, hope that helps. I'm interested if they're able to mount them, or explain why they say they can't on the 2016 Si
raffit78
by raffit78
Oh man these are great pictures! Thank you so so much man. Much appreciated. Emailing them over now.
Let's hope they can make it happen!
raffit78
by raffit78
raffit78 wrote:Oh man these are great pictures! Thank you so so much man. Much appreciated. Emailing them over now.
The crank in these pictures are sisl2?
evan326
by evan326
Please share the outcome. Hollowgram Si 172.5mm, the inner profile of the arms should be the same.
raffit78
by raffit78
I definitely will. I sent them pictures I took at my local LBS and sent yours as well.
evan326
by evan326
So?
are
by are
I'm also interested in this. Hollowgram sisl (not 2) on a 2017 Caad 12.
Sent from my Nexus 5 using Tapatalk
