New Dura Ace Di2 9150 connecting to Garmin Edge 1000
greenp
by greenp
Hi please can anyone help, I'am trying to connect Dura ace 9150 with my Garmin 1000 this will enable me to operate my garmin using the 2 hidden button on the shifters. My garmin edge 1000 can see the Di2 as its listed on the sensor page but the Di2 icon just flashes at the top of the garmin screen, when I select the sensor and select connect it just says connecting but never actually connects... any help appreciated .. Thanks Paul
greenp
by greenp
Hi cyclespeed my understanding is with the new Dura Ace 9150 I didn't need a D-Fly unit ?? am I wrong ... Thanks Paul
greenp
by greenp
cyclespeed
by cyclespeed
Sorry, but you do need a Dfly to communicate with the Garmin, even with the new 9150.
greenp
by greenp
Hi Thanks .. do you know a model/part number compatible with thr 9150please
TurboKoo
by TurboKoo
WU101 and WU111
Scott Foil
Shimano 9150
Shimano FCR-9100-P
Shimano C60 tubulars
p3dalfaster
by p3dalfaster
And It's best to install it within the frame - nice and hidden out the way then.
greenp
by greenp
Hi Turbokoo do I need both those item WU 101 and WU111 ?
Thanks p3dalfaster good tip
greenp
by greenp
Thanks for your help .... Do I also need a new Battery ?
TurboKoo
by TurboKoo
You only need either.
Scott Foil
Shimano 9150
Shimano FCR-9100-P
greenp
by greenp
Thanks again TurboKoo I will get WU 111 ... Must say I'm very surprised the New dura ace 9150 didn't come complete with this item !!!???
carbonLORD
by carbonLORD
I plugged my WU111 into the left shifter with a 200mm eTube wire, (since each shifter has 3 ports) and double stick tapped it under my Aeroad handlebar so it's hidden and right next to the Garmin. I'll post pics later. Works great!
carbonLORD.com
eaglejackson
by eaglejackson
greenp wrote:Thanks for your help .... Do I also need a new Battery ?
You need a D-Fly (either the EW-WU101 or the new EW-WU111) and a new battery (BT-DN110). Yes, it's a little surprising that the new DA still requires a D-Fly but so be it. Having the hidden buttons is a very nice feature.
cyclespeed
by cyclespeed
You don't need the new battery if you just want to talk to your Garmin. You DO need the new battery if you want Synchro Shift and/or Bluetooth.
