It is currently Mon Dec 18, 2017 8:38 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page 1 2 Next
PostPosted: Sat Mar 11, 2017 3:08 pm
Anyone have issues with this kit? I bought the internal brake kit, at the recommendation of Fairwheel Bikes, and since I have internal cable routing on my SL. Last night while attempting to install it, I notice that the length of I Links is considerably short. As in about 5" short. It also came with some normal 5mm cable housing which I thought was strange since it's supposed to be all I Link. At least that's what I thought.
Am I supposed to use the normal 5mm housing for the bars and add the I Link to that to run everywhere else?
As for the shifting system, the kit doesn't come with the proper 4mm ferrels to fit properly into the shifters (Campy) so the ferrel that is in the kit is just pushed up against the shifter body.
Am I missing something here? I figured that spending that kind of money on a cable system it would first be a pretty straight forward install, and that it would come with the proper pieces.
Oh and did I mention that the so-called instructions that are included, are completely worthless.
Please help!
PostPosted: Sat Mar 11, 2017 4:48 pm
there are videos on their website for each kit, check which you have...
http://www.alligatorcables.com/category ... e-Kit.html
PostPosted: Sat Mar 11, 2017 5:44 pm
It definitely shouldn't be short. Not sure how that could have happened. I run them upto and into the the shifter body. It probably isn't possible, but obviously you shouldn't be running the outers through the frame.
Supersix Evo Hi-Mod - 4.54kg
PostPosted: Sat Mar 11, 2017 6:14 pm
The normal housing I believe is to run under the bars (the extreme 90 deg angle) then continue towards the stem (the ilinks would kink at such an angle) with the ilinks and down to where they go into your frame.....
PostPosted: Sat Mar 11, 2017 7:02 pm
The housing is used from the shifters to where the bar tape ends. Once the bar tape ends you start the ilink system. The ferret should.be there as a converter. If not Jagwire makes them and if not then your local bike shop can find it and probably gift you it if you are a loyal customer.
Sent from my SM-G935W8 using Tapatalk
PostPosted: Sat Mar 11, 2017 11:45 pm
When did ilink start using normal housing out of the shifter? I thought it was only jagwiee that used this approach.
PostPosted: Sat Mar 11, 2017 11:56 pm
Yeh, I never had this with my i-links. I route mine through my bars and it's been less than ideal, so could help here. I think the wider part of the segment gets caught in the entry to the handlebar. Just under the tape it was great though.
PostPosted: Sun Mar 12, 2017 12:54 am
That's what I thought. I run the links all the way to the shifters. Never been an issue.
MAMIL? Never. O.F.I.L. yeh! (Old F**ker in Lycra)
PostPosted: Sun Mar 12, 2017 2:21 pm
Administrator
All the way to the shifters on my I-Link kits too. No regular housing. That would allow a small amount of flex into the system.
I have I -Links on all my bikes.
RESIDENT GRUMPY OLD MAN.
PostPosted: Sun Mar 12, 2017 6:15 pm
I've purchased quite a few of these kits and have never seen it shipped with normal housing. On campy though, the brake won't fit into the shifter. I work around this by running two cm of Powercordz swift housing which is smaller diameter for that last portion. They butte up against the ilinks well.
Strava
Current Stable. The Snob Machine | The Crumpton
The Ex's. LS Siena: 6.21kg | Parlee Z5 SLi: 5.9kg | LS Xicon: 5.76kg | C59: 5.7kg | Cervelo R5ca: 5.09kg | Fuji Altamira SE - 6.2kg | Scott Foil - 6.2kg | Evo - 5.18kg | LS Classic - 6.7kg
PostPosted: Mon Mar 13, 2017 1:28 am
I ended up just putting the standard housing under the bar tape to make it work. I emailed Fairwheel as well and will try to get some more of the Links. Not too happy with having to put the standard housing in there, but it's working fine now. The good thing at least is that the housing slid right into the shifter brake port.
PostPosted: Mon Mar 13, 2017 1:40 am
BigPoser, does your frame have cable stops for the rear brake cable?
PostPosted: Mon Mar 13, 2017 2:24 am
Yes it does.
PostPosted: Mon Mar 13, 2017 2:54 am
i don't use the std housing supplied with the jag wire either its a waste of time.. why add in the std housing and loose your non compression of the system :noidea:
Skunkworks Bikes
PostPosted: Mon Mar 13, 2017 3:12 am
I certainly didn't want too either, but couldn't wait another 3-4 days before I got more I Links shipped to me. I'll have to get some more and then redo them once I feel like it.
There are no new unread posts for this topic. Jagwire elite link brake cables
Chris3g
14
1037
Wed Nov 15, 2017 2:55 pm
CallumRD1 View the latest post
There are no new unread posts for this topic. Can you use a KMC power link on a 1/8 Izumi 1/8 chain
fozworth
Sun Dec 18, 2016 8:03 pm
fozworth View the latest post
There are no new unread posts for this topic. Alligator Ilink / Mini Ilink
Luca79
Tue Apr 04, 2017 12:34 pm
Mep View the latest post
There are no new unread posts for this topic. SRAM shifting with Di2
sturvey
Sat Mar 11, 2017 6:28 am
Racingevo View the latest post
There are no new unread posts for this topic. XG-1190 shifting
beanbiken
9
368
Thu Dec 14, 2017 9:48 am
2old4this View the latest post
Users browsing this forum: 4371, alistaird, Bing [Bot], colnagoaddict, CXrider, Google [Bot] and 31 guests
