Reach and top tube length
cmcdonnell
by cmcdonnell
Trying to work out how reach relates to top tube length (sorry if this is really obvious to some people) after having a recent bikefit and finding all my 52.5 cm top tube bikes need different length stems. Is reach top tube length - BB setback, i.e factor of seat tube angle? So a frame with a longer reach will require a shorter stem but a more setback seat post to get the same position?
Bianchi Oltre XR2 + Campagnolo Super Record 11 + Campagnolo Bora 50C
Litespeed T1 + Campagnolo Chorus 11 + Campagnolo Shamal Ultra
joejack951
by joejack951
Simple 'reach' as defined by the frame itself doesn't take into account other factors that determine the stem length you'll need. Saddle position relative to the BB (which can be, but isn't necessarily, affected by seat tube angle), handlebar geometry, saddle to bar drop, shifter design, and shifter placement all affect how far you need to truly *reach* from the saddle to your preferred handlebar position.
If you are solely comparing frames, stack and reach allow you to quickly get a sense if you'll be able to fit on those frames. If you are comparing two bikes, you need to look at more than just stack and reach which is what you are finding.
Calnago
by Calnago
"Reach", as you see it in geometry charts, is simply the horizontal distance from a vertical line through the BB to the center of the uppermost plane of your head tube. It is only comparable between bikes if you measure it at exactly the same stack height. Since bikes have different headtube lengths and angles, if you want to compare, a better place to measure reach would be at the point along the headtube axis where you want the bottom of your stem to begin.
Assuming you're after the similar fits it's rather puzzling why you have fitters putting you on different length stems on bikes with the same top tube lengths unless the height at which the stems are clamped is quite different among the bikes. Or the reach of the bars could be quite different? Not enough info to really say.
BdaGhisallo
by BdaGhisallo
You pretty much have it. Reach is another name for what used to be called the 'effective top tube'. It is a number for how much of the top tube is forward of the bottom bracket center. It's easy to imagine the effect of STA on frame reach for a given top tube length. Imagine a STA of 45 degrees - a huge chunk of the top tube will necessarily be behind the BB center and the frame reach will be very low. OTOH, if you had an STA of 90 degrees, all of the top tube would be forward of the BB center and the top tube length and the frame reach would be the same.
If your 52.5cm top tubed frames need different length stems to get your bars in the same spot, they must have different STAs and, perhaps, different HTAs though the effect of that on frame reach is much less than is the effect of the STA.
cmcdonnell
by cmcdonnell
thanks for the reply guys.
My T1 had a measured STA of nearer 73 vs the manufacturers quoted 74, my Oltre is 74.5. T1's quoted reach is 37.7 vs the Oltre's of 38.3. Both have stem and bars at the same height (both Deda RHM bars and -8 Stem). Front of saddle now at 5.5 cm behind BB. The T1 after the fit had a distance from nose of saddle to bar centre of 51.7 cm vs the Oltre at 52.6 cm both with 10 cm stems. Saddle and saddle heights are the same.
On my Ghisallo which has a 52.5 TT and a STA of 74 I can only achieve a distance of 4.5 cm behind the BB for the saddle nose even with the saddle all the way back on a 25mm setback post and the reach feels short (51 cm from nose of saddle to bar centre) even with an 11 cm stem!! There are no official reach and stack figures for my 2006 Ghisallo to my knowledge.
wingguy
by wingguy
cmcdonnell wrote:Trying to work out how reach relates to top tube length (sorry if this is really obvious to some people) after having a recent bikefit and finding all my 52.5 cm top tube bikes need different length stems. Is reach top tube length - BB setback, i.e factor of seat tube angle? So a frame with a longer reach will require a shorter stem but a more setback seat post to get the same position?
Reach does not directly relate to top tube length. Toptube length relates to seattube angle, Reach does not relate to seattube angle.
Reach is purely the measurement from the plane of the BB forward to the centre of the HT. This is why it's a more precise comparison between frames than toptube length. Assuming that you can achieve the same saddle setback between bikes, the precise seattube angle is irrelevant, therefore the length of toptube behind the plane of the BB is irrelevant, therefore the entire toptube length is irrelevant, and reach alone is what matters.
wingguy
by wingguy
BdaGhisallo wrote:You pretty much have it. Reach is another name for what used to be called the 'effective top tube'. It is a number for how much of the top tube is forward of the bottom bracket center.
That is not what effective toptube is. Effective toptube is an imaginary horizontal toptube on a bike that actually has a sloping toptube. Effective toptube still relates to seattube angle.
silvalis
by silvalis
cmcdonnell wrote:thanks for the reply guys.
Stem/bars at the same height, but are the stack heights of the stem/bars the same?
Chapter 2 Tere
Scott Spark 720plus
BdaGhisallo
by BdaGhisallo
That's what I recall it being used to refer to, dating back to well before Giant and their sloping top tubes appeared on the market back in 1998 or so. No doubt its usage has changed somewhat with the introduction of the term 'reach' into the cycling lexicon.
mpulsiv
by mpulsiv
Here's a great resource for you www.bikegeo.net
- A lot of people on WW forum are seagulls: they fly in, crap here, and fly away.
