It is currently Sat Dec 16, 2017 5:04 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
 Post subject: Re: Titanium Stems
PostPosted: Sat Mar 11, 2017 10:06 am
Looks like a very nice product! I had no idea this might exist.
Thanks!
PostPosted: Sat Mar 11, 2017 12:43 pm
Limited lengths though...
"It's not the destination...it's the ride!"
PostPosted: Sun Mar 12, 2017 11:30 pm
The 3 TTT stem is one of the stiffest titanium stems on the market so that shouldn't flex. If you go with any TI stem DO NOT use the titanium bolts that come with it, go down to your LBS and get a set of cromoly or stainless steel bolts instead, the TI bolts have been known to break under fairly light torque, and you don't want those failing on a ride. Yes the steel bolts will weigh more but only maybe 15 grams more.
PostPosted: Mon Mar 13, 2017 12:29 am
Thanks froze!
PostPosted: Mon Mar 13, 2017 8:00 am
Check out Ti Cycles in Portland Or. They make custom Ti stems.
PostPosted: Mon Mar 13, 2017 2:47 pm
Ok thanks Mike, I will keep that in mind!
PostPosted: Mon Mar 13, 2017 3:01 pm
a treadless conversion will open up more options for stems in Ti.
i assume that you plan to use this bike for commuting or just tossing around? if that's the case...it'll more than stiff enough for you which ever direction you take. a Ti quill stem will be harder to source in your length than a treadless option. when i did a conversion years ago when i had a quill stem, it was okay...not the best solution, but fine for commuting. since i don't commute anymore, i had no need for the older bike. i forget what adapter i used, but as @11.4 mentioned, a Nitto adapter will work for you. you can find various stems in Ti. Litespeed used to make quite a few. Moots is rather expensive. you can find various ones from China on eBay. J&L Titanium stems seem to be a good source.
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Mon Mar 13, 2017 3:07 pm
Ok thanks Kode54, I will keep that in mind as well. Yes this is a commuter bike. I think I may just go all the way and change the fork/headset to threadless eventually.
There are no new unread posts for this topic. Canyon stems
vinuneuro
Wed Mar 08, 2017 8:51 am
shotgun View the latest post
There are no new unread posts for this topic. Specialized S-works stems
rvlvr
Tue Aug 01, 2017 8:10 pm
rvlvr View the latest post
There are no new unread posts for this topic. Stems with internal cable routing
murphyk
Fri Oct 13, 2017 4:14 pm
kode54 View the latest post
There are no new unread posts for this topic. 0 Degree 1.25" Steerer Stems?
HugoDrax
Sun May 07, 2017 9:09 pm
HugoDrax View the latest post
There are no new unread posts for this topic. Fizik bars and stems 2018?
Titusrider
Mon Dec 04, 2017 11:02 pm
Titusrider View the latest post
Users browsing this forum: blacktalon, Google [Bot], Spooger, survivor and 37 guests
