It is currently Tue Oct 17, 2017 5:11 am
Post new topic  Reply to topic  [ 28 posts ]  Go to page 1 2 Next
PostPosted: Wed Mar 01, 2017 10:14 pm
I just purchased Record EPS V3. I am looking for inspiration on how to install/setup my cockpit area the cleanest. If anyone has pictures of theirs to share that would be awesome!
Thanks!
Also if anyone has any tips or advice I would greatly appreciate that as well! (Yes I have read through the forums)
PostPosted: Thu Mar 02, 2017 8:20 pm
If you tell us your frame make, model and size, I will be happy to provide tips. campy V3 over V2/V1 is really easy to set up in my opinion. I have Pinarello bikes, but I have seen Campy V3 installed on other bikes very clean and nice.
Let us know what you got and we can continue the conversation.
..A..
PostPosted: Thu Mar 02, 2017 10:03 pm
If you use a Computer on an out-front bracket just mount it beneath that - about as clean as your going to get.
PostPosted: Fri Mar 03, 2017 3:35 am
..A..
BMC Teammachine slr02. I believe I will have to slightly enlarged a couple holes to fit eps. I saw a slr01 so I know its possible, even though BMC creates their frames specifically for di2 only.
Thanks for your help!
PostPosted: Fri Mar 03, 2017 3:36 am
Do not use a computer unfortunately :/
PostPosted: Fri Mar 03, 2017 4:12 am
I think the best way is to just stick it under the stem with strong 3M double side tape or use the rubber bands provided with the interface.
another way is to stick it on the left side of the stem so you have easy access to the charge port. The charge port is small and I've seen a lot of people destroy it especially on the V2 battery due to poor charge port placement.
PostPosted: Fri Mar 03, 2017 4:02 pm
I have V3. One disappointment is I can't run the interface unit underneath my stem. I have 9 cm slammed stem with no spacers. V3 interface unit won't fit unlike my older V2 which fit fine. If my stem wasn't slammed it would fit instead it hits up against the head tube. I had to rotate it to the left side of the stem. I think the stem is the best place to mount it. The V3 interface is a bit more bulbous looking over V2. I don't think V3 can be mounted under a Barfly Garmin mount. I think that only worked with V2.
PostPosted: Fri Mar 03, 2017 9:17 pm
I have two V3 bikes with the interface under a Barfly mount. One is a 2.0:
The other is attached to a SLi 2.0:
PostPosted: Fri Mar 03, 2017 9:29 pm
very nice, thanks!!!
PostPosted: Sat Mar 04, 2017 3:52 am
For those using the deda superzero stem, there is a di2 clip made for that stem. I'm sure campy interface can be installed with small tie wraps.
PostPosted: Sat Mar 04, 2017 5:06 pm
I think under the stem is still the best location with the wires shrink-wrapped with non-segmented brake cable housing where possible.
PostPosted: Sat Mar 04, 2017 8:17 pm
Hey Keaton,
Here's my bike. Please note the red arrows. I use a 6mm spiral cable wrap, which you can find on eBay. There are several types out there. Some being more flimsy than others. The stronger, better quality ones is made by Panduit and it's the type that Campy provides with the EPS (although too short for this application). I could not see how they do the cable entry points on your BMC model. But Pinarello does a great job with this, especially if you want to use standard handlebars/stems.
I try to put the wrap on both, the front and rear brake cables, since this allows me to guide both shift cables neatly. I also try not to bend the interface cables too much. I liked the Campy V2 interface a bit better because it was more compact (rectangular) and I used to put it nicely on the curve of the rear brake cable, where I could see it. The new interface, IMO, is a bit bulky and hard to place anywhere other than the places where you see it in the pics that the others and me have provided. I am hoping Campy will do something about this with their V4 EPS. It's about time to get rid of the awkward charger/ connector, etc.
You may also want to look at pictures from other Pro bike set ups, such as Movistar and Lotto. They do nice clean jobs.
..A..
PHOTO 1
PHOTO 2
PHOTO 3
PostPosted: Sun Mar 05, 2017 1:16 am
3M tape to hold the junction box onto the stem and high quality electrical tape to reduce the spaghetti.
My Protos
My XR4
PostPosted: Mon Mar 06, 2017 4:41 pm
[quote="avispa"]Hey Keaton,
I try to put the wrap on both, the front and rear brake cables, since this allows me to guide both shift cables neatly. I also try not to bend the interface cables too much. I liked the Campy V2 interface a bit better because it was more compact (rectangular) and I used to put it nicely on the curve of the rear brake cable, where I could see it. The new interface, IMO, is a bit bulky and hard to place anywhere other than the places where you see it in the pics that the others and me have provided. I am hoping Campy will do something about this with their V4 EPS. It's about time to get rid of the awkward charger connector, etc.
..A..
Very nice! Thanks for the input!!!!
PostPosted: Mon Mar 06, 2017 4:42 pm
Seedster wrote:
:D
There are no new unread posts for this topic. Attachment(s) Campagnolo 11 speed using 34/50x11/36! Yes it can be done with PRE-2015 Athena LC Big Gears on Campagnolo 11 speed
colnagoaddict
12
690
Mon Aug 28, 2017 12:26 am
c50jim View the latest post
There are no new unread posts for this topic. Questions on Campagnolo EPS
mlok
Mon Oct 16, 2017 4:15 am
avispa View the latest post
There are no new unread posts for this topic. Attachment(s) Campagnolo wheels??
53cxzero
15
3118
Fri Jan 06, 2017 9:30 pm
5 8 5 View the latest post
There are no new unread posts for this topic. Campagnolo EPS - V2 versus V3
gerryc89
13
2195
Mon May 22, 2017 2:28 am
mvacolnago View the latest post
There are no new unread posts for this topic. Campagnolo Lockring
3Pio
9
671
Sun Dec 18, 2016 12:41 pm
bikerjulio View the latest post
Users browsing this forum: beanbiken, kurisu, nick312, Yahoo [Bot] and 39 guests
