It is currently Thu Mar 30, 2017 12:29 am
Post new topic  Reply to topic  [ 19 posts ]  Go to page 1 2 Next
PostPosted: Wed Mar 01, 2017 2:30 pm
Interested in a pair of Campag Bora One 35mm clinchers. Advertised as 1407g - can anyone verify if this weight is accurate? Ta,
Simplon Pavo III viewtopic.php?f=10&t=116069"
PostPosted: Wed Mar 01, 2017 2:44 pm
Can't comment on the Bora One 35 but my Bora 50 Ultra clincher and Shamal Clinchers are both 10g under Campagnolo's quoted weight so I doubt they would be far off.
Bianchi Oltre XR2 + Campagnolo Super Record 11 + Campagnolo Bora 50C
Litespeed T1 + Campagnolo Chorus 11 + Campagnolo Shamal Ultra
Litespeed Ghisallo + Campagnolo Chorus 10 + Campagnolo Neutron Ultra
PostPosted: Wed Mar 01, 2017 2:49 pm
My Bora One 35 clincher wheel set weighs in at 1390 grams. So ~17 grams lighter than published weight.
It's all downhill from here, except for the uphills.
PostPosted: Wed Mar 01, 2017 4:56 pm
Thanks guys, sounds good so far!
PostPosted: Wed Mar 01, 2017 5:48 pm
Mine were again 11gr less than that, 1379gr to be exact.
Canyon Ultimate CF SLX 2013
Scott Addict Orica Greenedge
Canyon Endurace CF SLX
PostPosted: Wed Mar 01, 2017 6:13 pm
How good are they for an everyday wheel?
I was considering buying the shamal mille, but having read the brake tracks do tend to loose the coating, I'd consider this one.
Although at 82Kg I'm not the lightest rider, and I'm certainly not the best descending - reason I was considering going for aluminium wheels instead of FCC.
PS: either carbon or aluminium, the black brake track really is mandatory for me :D :D
PostPosted: Wed Mar 01, 2017 10:07 pm
I own a set of Shamal C15 clinchers , a set of Bora One 35 clinchers, and a set of Bora One 50 tubulars. I use the Bora One 35 clinchers the most on my Dogma F8, except when I anticipate long, steep alpine descents. I use the Bora 50 tubulars mostly for racing. The Shamal C15 clinchers are on my Dogma 65.1. So I can pick and choose depending on my ride. I would like to get a set of Shamal Mille C17 clinchers eventually.
PostPosted: Wed Mar 01, 2017 10:23 pm
Around 10.000km on my Bora 35's (clincher) in 2016 and not a single issue. I've done everything on it, except long Alpine descents, but even middle mountain stages or cobbles are no problem at all.
PostPosted: Wed Mar 01, 2017 10:57 pm
Great guys, thanks for the help!
@fogman they are meant for a F8 too, cheers!
PostPosted: Thu Mar 02, 2017 4:04 am
My 35 Dark Label clincher without warning stikers
PostPosted: Thu Mar 02, 2017 10:37 am
Go for the Bora 50. I had the 35 vs 50 dilemma a couple of years back and eventually went for the 50's. I was worried about the extra weight and winds (i live in a windy, flat area) because I'm quite light at 58kg. I have no issues at all and when in the alps they were fine climbing and descending. They climb as well as the Shamals and descend quicker. Not tried descending in the wet though and would probably avoid it if I could but that applies to all carbon clinchers.
PostPosted: Thu Mar 02, 2017 11:51 am
Thanks for the replies guys. Ordered a set of Dark Label from Wiggle last night so hopefully they should be here in a few days and I'll post the weights asap. Do Campag provide brake pads with these wheels? If not, what's the preferred choice? Cheers.
PostPosted: Thu Mar 02, 2017 12:42 pm
campagnolo supply a set of their red brake pads with the boras - use these, they're great pads!
PostPosted: Thu Mar 02, 2017 12:49 pm
+1 the red pads are the best!
PostPosted: Fri Mar 03, 2017 4:40 pm
Real weight 1395gr on mine without qr. Great wheelset. I enjoyed this so much I almost forgot I still have shamal mille (originally thought I need alu clincher for descending)
There are no new unread posts for this topic. Bora 35mm One brand new - or - Bora 35mm Ultra used
ronderman
23
3162
Sat Nov 05, 2016 4:51 am
karng View the latest post
There are no new unread posts for this topic. Need Help Please Campag Bora ultra two Dark Label
Snugship0
13
589
Tue Feb 07, 2017 10:34 am
graeme_f_k View the latest post
There are no new unread posts for this topic. Campag Bora Ultra two needs turing - whats the advice for taking care
ViggenNut
Thu Mar 23, 2017 7:57 pm
colster View the latest post
There are no new unread posts for this topic. Changing free-hub body Campa bora Clincher???
poppiholla
9
573
Sun May 22, 2016 12:21 am
fh8425 View the latest post
There are no new unread posts for this topic. Bora Rim Weight
prglewis
Sun Oct 02, 2016 9:34 pm
prglewis View the latest post
Users browsing this forum: beeatnik, Yahoo [Bot] and 19 guests
