Tune skyline skewers gained weight!
Kayrehn
by Kayrehn
Just got a pair of the road version and found out the weight was Image which corresponded to the specs on the manual. What happened to the sub-18g pairs?? Did it gained weight because of failures?
NiFTY
by NiFTY
Silver axle looks like ti. Those are the mountain bike ones.
mrlobber
by mrlobber
Will get a pair in a couple of days as well, will be able to compare.
However, check this out: http://www.tune.de/en/produkt/zfs, 24g
Then again, bike24, for instance, still has a description of 19g: https://www.bike24.com/1.php?menu=1000% ... oduct=8743
Kayrehn
by Kayrehn
It's still 17.5g on starbike too. I emailed them and they said they/Tune might have sent the wrong item and will check it out when the item is received (I've just returned them)
4ibanez
by 4ibanez
I bought Tune (road) time trial skewers recently. The road ones are black anodised on the shaft. Mine are pretty much bang on claimed weight. Unfortunately you have the mtb ones based on appearance and weight. Mine:
UpFromOne
by UpFromOne
And here I thought only the aptly-named U20s were under 20.
Those thin end nuts on the skylines make them 135mm, but the thicker ones are for 130 road. Same axle length IIRC.
RyanH
by RyanH
Those are the MTB ones and that weight is right for the MTB ones.
Strava
Kayrehn
by Kayrehn
I thought I checked the manual and it says road version but without a pic of it I could be mistaken. Let's see what Starbike says when they received it or if @mrlobber gives a report here first.
The updated tune website on the skewers does seems to suggest that weight is added to beef it up for different applications. Seems like a streamlining of product range...
mrlobber
by mrlobber
Received mine today. All black axle, as in the pic 4ibanez posted. 18g on my kitchen (or bike parts :D) scales.
