It is currently Sat Dec 16, 2017 6:59 am
PostPosted: Mon Feb 20, 2017 11:33 pm
Anybody using a Fetha Garmin mount on the newer style Zipp Service Course SL Stem with the wider face plate. I have the Zipp stem on the way but want to order the fetha mount so they will both arrive around the same time. The problem is I do not know the center to center measurement of the faceplate bolts without having the stem in front of me. Does anybody out there remember what width fetha mount they ordered or do you know the center to center measurement of the faceplate bolts. Thanks.
PostPosted: Tue Feb 21, 2017 12:13 am
27 mm
(And yes, that tower of spacers is embarassing)
PostPosted: Tue Feb 21, 2017 12:18 am
Awesome. Thank you for taking the time to take a picture of it no less. That's why I love this forum.
PostPosted: Tue Feb 21, 2017 12:22 am
No worries... Fyi, Tillquist also has a version available for Zipp / 27mm
Enviado do meu iPhone usando Tapatalk
PostPosted: Tue Feb 21, 2017 12:56 am
Thanks for the info I will check out his mounts as well.
PostPosted: Tue Feb 21, 2017 12:10 pm
I have the Fetha mount and it sucks- there's a completely unnecessary bolt to adjust rise but only +Ve not negative (so the Garmin can't be positioned flat). Fetha do a bolt-less design for 3T stems, similar to the enve mount, much better design.
PostPosted: Tue Feb 21, 2017 3:22 pm
I placed an order for the new fetha slim adjustable aluminum mount which says it can go -5 degrees down from the flat position. I guess I will find out when it arrives if that is true.
PostPosted: Tue Feb 21, 2017 4:13 pm
Still waiting on my Fetha (custom long 21mm for S5 aerobars that will fit on lower ENVE stem bolts). Said it would ship last week but gone quiet. Not sure what's happening.
Email from Zipp (I asked them for faceplate bolt measurements for this reason before)
Hi xxxx,
Thanks for contacting us.
Here are the measurements:
Bolt to bolt of the Service Course and OS (Speed I think they meant here, which was what I asked them for) is 27mm
SL Sprint is 33mm
There are no new unread posts for this topic. Fetha mount on Zipp Sprint stem?
SpecializedColnago
Wed Apr 19, 2017 3:53 pm
SpecializedColnago View the latest post
There are no new unread posts for this topic. Space for a Wahoo mount with Zipp SL Sprint + Zipp SL 70 Aero setup?
Shrike
Fri Nov 17, 2017 10:08 am
Shrike View the latest post
There are no new unread posts for this topic. GoPro stem mount ?
Allen254
10
1018
Sat Jan 07, 2017 8:16 am
spookyload View the latest post
There are no new unread posts for this topic. Fetha for S-Series aerobars
Shrike
Fri Mar 17, 2017 11:59 am
mrlobber View the latest post
There are no new unread posts for this topic. Converting flat mount to post mount
Miller
Wed Mar 01, 2017 11:55 am
Broady View the latest post
Users browsing this forum: Bing [Bot], Google Adsense [Bot], russianbear, trikobe and 36 guests
