It is currently Tue Oct 17, 2017 5:11 am
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Sun Feb 19, 2017 8:16 am
Yesterday I changed the front pads. I suspect Canyon had not mounted the calipers very very straight in the factory, so the pads were worn, but not even, and thought it wwas time for some new ones, and time for caliper alignement job. What I did
*after removing the old pads, I very gently tried to push back the pistons. I even put in the yellow piston blocker to be sure the pistons where all the way back;
*Installed the new pads
*Put in the red pad spacer, and squezed the lever a couple of times
*Put the wheel back in. As I have TA's, wheel can only be in the same exact place as before
*Loosened the caliper bolt, squeeze the lever, rebolt the caliper and loose the lever after it.
Result : lots of pads drag, and very little brake lever stroke before the brakes actually begin to brake. Compared to the rear, the difference is huge! When I look at the calipers, I notice there is almost 0 clearance between pads and disc, and this on both sides. After more than a hour of micro shimming, I managed to get the wheel turning 99% rub free, but I do not feel confortable the way it is.
What have I done wrong? Thepads are the same reference aas the old ones, so, that's not the cause.
Canyon Ultimate CF SLX 2013
Scott Addict Orica Greenedge
Canyon Endurace CF SLX
PostPosted: Sun Feb 19, 2017 8:53 am
Are these hydraulic calipers? My sram red 22 hydraulic calipers had air lock, I need to bleed the hydraulic before it could brake properly. After bleeding it, it was smooth.
PostPosted: Sun Feb 19, 2017 9:13 am
Bleed the brakes...
If you are running discs purchase a kit to DIY
PostPosted: Sun Feb 19, 2017 11:09 pm
Short of doing a complete system bleed, you can do this in a pinch if you don't have a bleed kit or the know-how. I'm assuming you are running Shimano road brakes by the mention of the red pad spacer. It will work for MTB as well. Your road caliper will have either one of two bleed nipple arrangements....... A hidden nipple that is covered by a small flush mounted rubber plug. Above that plug will be a 3mm allen head screw. OR a protruding nipple with a rubber cap and leash attached to it, actuated by a 7mm wrench. Either very slightly open the nipple by either turning the wrench flat about an eighth of a turn, or open the 3mm hex screw an eighth of a turn. A very small amount of mineral oil may come out. Have the pads removed before hand to avoid contamination. With the bleed port still slightly open, retract the pistons again with a tire lever or something plastic. This will create the space and stroke you are looking for.
There are no new unread posts for this topic. Disc Brake Pads - What's Best for Stopping Power
Mr.Gib
22
1530
Thu Oct 20, 2016 4:58 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Brake pads for Lightweight Meilenstein
mike001100
12
542
Thu Aug 31, 2017 2:04 pm
Geoff View the latest post
There are no new unread posts for this topic. Attachment(s) Why is no one using disc brakes in the tour?
[ Go to page: 19 10 11 12 13 ]
gceniza
186
16293
Sat Jul 22, 2017 8:29 am
lobuxracer View the latest post
There are no new unread posts for this topic. Road Disc Brakes- Rotor Choice
[ Go to page: 1 2 3 4 5 ]
mdeth1313
62
4834
Mon Sep 25, 2017 12:33 pm
Lewn777 View the latest post
There are no new unread posts for this topic. How many of you have converted to Disc Brake?
[ Go to page: 14 5 6 7 8 ]
gravity
111
8557
Mon Apr 10, 2017 7:53 am
jlok View the latest post
Users browsing this forum: beanbiken, Bing [Bot], kurisu, MomentumR5, nick312, Yahoo [Bot] and 40 guests
