Frame Plugs?
Wormiez
by Wormiez
Hi All,
I am looking for frame plugs to fill in the internal cable routing holes. Two up front and one for the rear derail-er cable hole.
Asking because I finished a new build with Etap... Etap only required two cables..
Any suggestions would be appreciated :)
tilf
by tilf
Sugru
oldnslow2
by oldnslow2
What frame?
I have a Trek Emonda and used (2) Di2 closed covers for the downtube and found a rubber plug for the RD exit.
Wormiez
by Wormiez
The bike is a Time Skylon
See pic of the holes iam looking to plug
leej88
by leej88
Wormiez wrote:The bike is a Time Skylon
Time includes plugs for their Skylon/Scylon frames. Look through the pack of accessories that came along with the bike. You should be able to spot them.
If not, go to your TIME dealer and ask for some.
Also, since you're not using the RD and FD internal cable holes, I presume you're running an electronic groupset?
If it's Campy/Shimano, you'll have to purchase the electronic mounting kit that comes with two plugs that fit nicely into the holes.
However, if it's SRAM eTap that you're talking about, then you wouldn't need the electronic mounting kit and thus might not have the plugs.
Here's one for the right side
One for the left side
Rear Derailleur cable stop
And a small plug to plug the mechanical Front Derailleur cable exit hole
JackRussellRacing
by JackRussellRacing
Sugru +1
