It is currently Sun Jan 21, 2018 11:46 pm
Post new topic  Reply to topic  [ 114 posts ]  Go to page Previous 14 5 6 7 8
PostPosted: Sat Aug 05, 2017 2:16 pm
New shoes!
PostPosted: Sat Aug 05, 2017 2:23 pm
5.88kgs with ax 45c Ultra ceramic, 23mm GP4000 II and 78g Michelin aircomp tubes. Will also give them a try with 25mm as they are very wide rims.
PostPosted: Sat Aug 05, 2017 7:01 pm
All of those lined up logos make me feel really good inside.
My Strava Profile
2016 Cannondale CAAD12
PostPosted: Sat Aug 12, 2017 2:38 am
Really, really nice. Well done.
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Sat Aug 12, 2017 7:51 am
Fantastic! Agree with all the component choices - brakes are not a place to skimp on performance. I've also had good experiences with Praxis Buzz.
Could I suggest switching the rubber to Continental GPTT? They are some of the fastest tyres tested on Bicyclerollingresistance, would save you 50g per pair even if you moved up to the 25mm version, and still have a puncture resistant strip and don't seem to be crazy fragile - the rubber is the same, you just carry around less of it. Still has the German/all black matchy matchy look as well.
Obviously it would increase your puncture risk and your running costs in terms of consumables but would probably make more difference to performance and feel than +/- 500 g in weight.
PostPosted: Sat Aug 12, 2017 8:09 am
Thanks kode54!
petromyzon, thanks, good idea with regarding the TT's, I've already switched out the 23mm GP4000II for 25mm Michelin Power competitions and Mavic 80g (measured 90g) tubes.
the reason for the switch was I've always been very happy with Michelin Pro 4 Comps and Michelin Latex tubes, the 23mm seemed a little narrow on the very wide 26mm AX rims so went for the 25mm. I have been thinking of good weight/puncture protection tyres. Given the 25mm even tubes became a bit of a compromise. I like smooth valves and don't want to run latex on carbon rims, so Michelin Ultra lights were not bad at around 76g but they only go up to 23mm, the regular Michelins are heavy that support 25mm so the Mavic seemed good at quoted 80g and supporting 25mm, bonus is the smooth black valve stems..shame they came up even heavier.. I used to run the 50g conti tubes on narrow Mavic rims and even then had too may flats..the Cont TT in 25mm are 190g and the Power Comps I'm running are 211g on my scales, still not bad saving 42g... would love to hear more about how punctury the TT are compared the 4000's.. and if they feel as nice as the Michelins..
Any thoughts? As you can probably tell by the point in the build, there is not much left for me to do! So mucking about with the right balance of tubes and tyres is about it!
PostPosted: Sat Aug 12, 2017 9:12 am
sp3000 wrote:
Thanks kode54!
From a riding perspective I prefer the Michelin Pro 4 Comps to the Contis.
Why no latex with carbon clinchers? Is it the potential of heat build up causing punctures?
PostPosted: Sat Aug 12, 2017 1:15 pm
Yeah, the heat. I'm sure it can be ok and plenty of people are doing it, but every carbon rim manufacturer advise against it and for a nominal watt saving I have little interest in trying to prove them wrong.
PostPosted: Sat Aug 12, 2017 9:05 pm
When I first went to latex tubes I didn't feel that much difference. We've had fairly poor conditions for the last few weeks, so I've ridden the Tarmac (edit: with clinchers and latex tubes) for a couple of 50s having been on Conti tubs for a couple of months. It's sooooo plush by comparison despite the tubular/clincher factor.
Supersix Evo Hi-Mod - 4.51kg
There are no new unread posts for this topic. I Need Help about Ax lightness Vial Racing with AX Europa Premium
Ashut
Wed Apr 12, 2017 2:14 pm
sp3000 View the latest post
There are no new unread posts for this topic. Ax Lightness Vial Evo Frame & Morpheus Crankset, rubbing at the BB
DEADRE
Fri Jul 07, 2017 5:30 am
DEADRE View the latest post
There are no new unread posts for this topic. Sportful BodyFit Pro Race vs Castelli Aero Race 5 sizing and fit
jlok
Wed Oct 11, 2017 12:24 am
sanrensho View the latest post
There are no new unread posts for this topic. Attachment(s) Berk Lupine, Ax Lightness Leaf II. .
MyM3Coupe
34
5200
Tue Jun 20, 2017 11:13 pm
Vuong05 View the latest post
There are no new unread posts for this topic. Attachment(s) Ax Lightness Leaf vs Dash M4 saddle
Luca79
10
1695
Wed Apr 12, 2017 5:25 am
spdntrxi View the latest post
Users browsing this forum: ArtV, bfno, Bing [Bot], dbnm, Hexsense, jimaizumi, MC356, taztaylortaz and 34 guests
