It is currently Fri Dec 15, 2017 8:59 pm
Post new topic  Reply to topic  [ 43 posts ]  Go to page Previous 1 2 3
PostPosted: Wed Mar 29, 2017 6:51 pm
I like that idea , in fact I'll try it myself - I think I have a 1mm spacer lying about somewhere
Darren
dorin wrote:
I ordered 2 spacers, the ones coming with the wheel sets are all 1.75mm, I hope 1 mm should work. I can close the lock ring but the 11 cog spins freely, let me try with the 1mm ones, the cost is ridiculously low (2usd)
Thanks for the tip, I'll report once I have it
Cheers, Dorin
PinaRene wrote:
TIP :
* What I did with my 11- speed wheels ( Bora One / Mavic CCU / Ultegra 6800 ) is a 1mm spacer ring behind the big cog like normally done on the 10 speed cassettes. Maybe I will let my colleague make some 0.7mm aluminium spacers in the future.
Now they all work well and fit the frame fine. The best thing is that the rear derailleur isn't touching the spokes anymore on the Bora wheels while the chain is off. The only thing you have to take care of, is that the lockring still works fine and has enough thread in the body.
I use a 12-28 cassette on the Bora's and the hardest thing was to get the rear derailleur on the 12. Limit screw is just touching and then it's perfect now.
This is just 1mm in real life between derailleur and spoke 8)
PostPosted: Sun Apr 16, 2017 1:33 pm
Darren
Cheers, Dorin
And did you try it ?
Scott Foil Team edition / Holdsworth Competition / Gluing tubular and add water.
PostPosted: Sun Apr 16, 2017 1:38 pm
Not yet - totally forgot about it , but I have some spare time this week to give it a go
PostPosted: Sun Apr 16, 2017 1:42 pm
sorry, in holidays, will try in 2 weeks or so, i did get the spacers just on 10th...
PostPosted: Thu Apr 27, 2017 8:14 pm
I've managed to get a .8mm spacer i'm going to fit tomorrow - i'll let you know how i get on!
Darren
PostPosted: Fri Apr 28, 2017 12:23 pm
OK ,
I fitted the .8mm spacer this morning and refitted the wheel - for me this did not work - with the extra spacer fitted , the slight dome shape of the locking was just touching the frame causing the wheel to bind a little as it span.
So i've gone back to how it originally was and fitted a sram chain catcher for a spot of added insurance.
Darren
PostPosted: Mon May 08, 2017 3:05 pm
Given the range of frames and wheels described in this thread it's sounds like there are very few configurations out there in the wild that could even be considered 'compatible'. Sorry, but I'm 100% with those who think this deraileur-in-the-spoke situation is a horrible, horrible liability.
So we need to come up with some solutions for those who don't have one of these mythical compatible solutions as it looks like SRAM has no interest.
Solution #1 seems to be to buy a SRAM chain catcher which theoretically solves for the more common scenario of the dropped chain. It will keep the chain from falling off the inner chainring on the front, presumably keeping just enough tension on the chain to prevent the rear deraileur from jamming into the spokes.
Now for the mad scientist stuff:
Potential Solution: @sugarkane mentioned something in the linked thread about "SRAM mechs don't use a sprung pivot like campag and shimano". Does anyone know if such a spring can be swapped in?
Potential Solution: You know how Canondale has their "lefty" fork where the front wheel is held on by only one fork leg? Could a similar strategy be employed in which the bottom pulley jockey is held on by only the outer bolt, freeing up multiple mm on the inside where the arm would otherwise rub? If the remaining arm were stiff enough I don't see any reason why this would have to hurt shifting performance.
Or perhaps the cage could be left mostly intact, but the inner bottom portion below the axle area could be removed. If the chain breaks that safety ridge isn't going to keep the chain attached to the bike so it's mostly useless.
I've attached photos of my rather unfortunate spoke-hitting scenario: Merlin Works CR, Mavic Cosmic SLR with carbon spokes, Shimano 11sp cassette on Shimano 10/11sp freewheel body. My bike is currently sitting in the shop and they've swapped our deraileurs, wheels and put washers on the dropout and on the inner of the freewheel body. They have also swapped in a SRAM cassette. Nothing is getting that deraileur off the spokes as it stands!
PostPosted: Mon May 08, 2017 5:42 pm
Edit: I see you've tried the washer inside the drive-side hub. I'm surprised that didn't work. I wonder if a trispoke or disc rear would have the same issue.
PostPosted: Fri May 26, 2017 3:45 pm
Update time with bad news and good news.
The bad news is that I don't have a solution for a Canyon CF SLX. The good news is that I have a solution for the Merlin Works CR/Mavic Cosmic SLS (and possibly older mavic wheels more generically). It looks like everyone is going to end up with their own custom config with your worst case being the possibility of having to switch out your wheels or do something scary to your deraileur.
Before I dive in your experience may vary widely--I've got a buddy who took his Scott Addict with custom bikehubstore.com wheels and milled out the back of his Ultegra cassette and jammed it on a 10sp body, essentially moving everything CLOSER to the hub. Meanwhile on the opposite end I needed to move it AWAY from the hub using a new freehub body described below.
Lastly, Mavic seemed surprisingly unknowledgeable about the issue, despite countless wheels going through the 10sp -> 11sp transition. FWIW they did offer to 're-dish' my wheel if it came to that. I don't know much about the process but given that I've got about 5mm between my 23mm tires and my frame, I'm glad to not need that.
So, for older mavic wheels it all boils down to the freehub body.
Details are scarce and there is a lot of documentation that suggests that you can take a 10sp freehub body, remove the spacers that come with it, slap on a 11sp cassette and you're off and running, but that was definitely not the case for me.
Looking at the OUTSIDE newer 11sp freehub body next to the older 10/11sp freehub body you wonder how on earth the 11sp is going to fix the spacing problem (they are all but identical), but if you look INSIDE the newer 11sp freehub bodies have an extra washer which effectively pushes the entire thing out and away from your hub. This made all the difference:
Could it be that simple?! It appears so:
Just as confirmation, the cassette body is exactly the same size on the outside so that lil 11 tooth cog isn't getting pushed out or anything:
Out of an abundance of caution, and because I didn't believe the freehub body would fix the problem I picked up a SRAM chain catcher. It's like a dream catcher, except for chainrings:
So hopefully that helps some Mavic people. Good luck to everyone else! I'm going to stay subscribed to this thread to see how things continue to shake out.
PostPosted: Fri May 26, 2017 6:16 pm
When you have spent a good chunk of your money to "upgrade" to ETAP, you should not be expected to make any modification for it to work properly. I had so many issues with my Etap regarding this and drop chain, that I ended up giving up and go back to mechanical. Good luck OP, i hope you get all this sorted out.
PostPosted: Fri May 26, 2017 9:14 pm
I have 2 bikes built up with eTap and have noticed this issue on both. My solution is to just make sure my chains get swapped before they're heavily worn so there is no chance of it breaking. Presents zero issue when the chain is installed.
PostPosted: Tue Jun 13, 2017 4:27 pm
I am overdue with an update here! I tried the 1mm spacer and worked great, hopefully will. It have to ever be proven right or wrong :)
PostPosted: Tue Jun 27, 2017 8:29 am
Another update: I upgraded to a WifLi derailleur and I had the same issue, problem solved with the spacer and kept a higher distance on the B-adj screw as if I was leaving it 4-6mm as said in manual, when there is no chain attached the jokey wheel hits the biggest cog. Had a mountain pass ride, all went flawlessly and having a 11-32 is awoesome.
Maybe some manufacturers have different distances on their RD hangers as having the same issue with WifLi rules out defective RD.
The spacer solution worked for me.
Cheers,
Dorin
There are no new unread posts for this topic. eTap Rear Derailleur seems dead
Shrike
41
5796
Tue Jul 18, 2017 12:56 am
colnagoc59 View the latest post
There are no new unread posts for this topic. SRAM etap rear derailleur
aerozy
10
714
Fri Nov 17, 2017 3:06 am
charlieboy52000 View the latest post
There are no new unread posts for this topic. Sram etap rear derailleur problem
srammer
Tue May 30, 2017 4:25 pm
sungod View the latest post
There are no new unread posts for this topic. SRAM Etap and Cannondale Supersix : clash in the spokes !
Didier
24
4408
Fri Jun 02, 2017 2:48 pm
strayduck View the latest post
There are no new unread posts for this topic. Sram Etap Front Derailleur Height
goldmine848
Thu Jun 22, 2017 10:25 am
goldmine848 View the latest post
Users browsing this forum: Bing [Bot], Digger90, Google [Bot], Google Adsense [Bot], Hapsmo911, slowK and 40 guests
