It is currently Tue Jan 16, 2018 9:01 am
Post new topic  Reply to topic  [ 5 posts ]
 Post subject: Qxl and Q rings
PostPosted: Mon Feb 06, 2017 7:38 pm
I've been a long time use of rotors oval rings and have always wanted to try the Qxls but with a 130bcd chainset the qxl is only avaliable in 53/40. Would shifting be affected if I used a qxl out and a q ring inner? Many thanks, Tom
C60 race bike
 Post subject: Re: Qxl and Q rings
PostPosted: Mon Feb 06, 2017 9:20 pm
Theoretically it should work as they are just different ovalizations. I used a round outer with an internal oval because I found it helped my climbing and it shifted and such just fine. Though, you will probably notice shifting not quite as great as two round.
BMC SLR01 2015
Redline Conquest Team
PostPosted: Tue Feb 07, 2017 2:35 pm
I have done this successfully for the mountain and it works, even a 53*36. Shifting must be adjusted and chain length must be properly chosen.
The main issue is on feelings, it's hard to find the good pedal stroke when you change from the 53 to the 36T, still need a few miles to get used to this setup.
If you ride long climbs, it's fine, if you climb hills, it's better to find bigger rings on your cassette and keep 53*40 QXL.
http://www.velo-perso.com
PostPosted: Tue Feb 07, 2017 6:30 pm
Actually I run that now... I changed my big ring to the QXL after about 15,000 miles and my inner ring was barely used so I just kept it. I actually feel like the QXL is much stiffer then my original Q and it shifts perfectly between the two....
PostPosted: Tue Feb 07, 2017 6:41 pm
Thanks for the advice guys, being a bigger built guy I stick to crits and flat races so the inner ring is mainly redundant but will head for the hills for training so the 39 is a must. Been looking at a rotor dealer in the UK and they will do spider conversion so maybe get a 110bcd and use a full qxl set up
C60 race bike
There are no new unread posts for this topic. FC-9000 crank with 56-44 rings or just the rings
lactatehate
Tue Apr 18, 2017 3:13 am
FIJIGabe View the latest post
There are no new unread posts for this topic. Quarq Dfour with Rotor QXL rings
TroyG
Fri Jul 28, 2017 6:13 am
TobinHatesYou View the latest post
There are no new unread posts for this topic. Q rings for Campagnolo 4arm crankset ?
stormur
Fri Jul 28, 2017 3:29 am
CycloTron View the latest post
There are no new unread posts for this topic. Cutting q-rings to fit quarq dzero?
dairic
Sun Sep 10, 2017 7:20 pm
There are no new unread posts for this topic. Campagnolo Delta Brake O rings
c60rider
Fri Jun 23, 2017 7:48 am
kgt View the latest post
Users browsing this forum: Baidu [Spider], L3X, lovemyway, praem and 39 guests
cron
