Fiery wrote:prebsy wrote:Control viento CL because it's the only classic bend 38cm alloy bar
Any pictures?
One of the stranger builds I've used them for.
Sent from my KIW-L24 using Tapatalk
prebsy wrote:Fiery wrote:prebsy wrote:Control viento CL because it's the only classic bend 38cm alloy bar
Any pictures?
One of the stranger builds I've used them for. https://uploads.tapatalk-cdn.com/20170201/925db53af0b7c64421709771c87cbae2.jpg
Calnago wrote:The Deda Zero 100, Superleggera, and Presa all share a very similar bend (RHM... I think that's Deda's abbreviation for "Rapid Hand Movement"). The Deda Zero100 SHALLOW is quite different, much more of a classic shape with a ramp downwards for placement of the levers (especially Campy) in the traditional type placement which allows for easy reach to the levers, even when in the drops. The ironic thing about Deda calling these SHALLOW is that they have a 135mm drop, deeper than any of the other bars I quoted above. I find the RHM bend favors a more flat (on top) transition to the levers, a shallower drop, but more difficult to reach the levers from the drops unless you're right up there in the hooks. Again, comes down to personal preference. I had the Presa's when they came out and could never get used to them. I didn't like the "squashed" part of the tops of the bars because you had to have them in exactly one place otherwise the edge was always bothering my palms. I like round top bars for that reason... you can tilt them exactly how you like and the grip on top is always the same.
Deda Zero100 SHALLOW from the side.... tips of Campy levers level with a line horizontal along the straight line edge of the flat drops. That's the other thing I really like about these bars... a flat straight area on the drops versus a constant curve to the very end....
benzebub wrote:I like the Zipp service course sl-80 myself very much. I love the long drop section which gives me plenty of space to move around.
On my current bike I have to go down 0.5cm in reach, which I can't do with a stem, does anyone know a bar that has 75mm reach and a similar shape as the zipp sl-80? the specialized expert compact looks to fit the bill..
micro553 wrote:Calnago wrote:The Deda Zero 100, Superleggera, and Presa all share a very similar bend (RHM... I think that's Deda's abbreviation for "Rapid Hand Movement"). The Deda Zero100 SHALLOW is quite different, much more of a classic shape with a ramp downwards for placement of the levers (especially Campy) in the traditional type placement which allows for easy reach to the levers, even when in the drops. The ironic thing about Deda calling these SHALLOW is that they have a 135mm drop, deeper than any of the other bars I quoted above. I find the RHM bend favors a more flat (on top) transition to the levers, a shallower drop, but more difficult to reach the levers from the drops unless you're right up there in the hooks. Again, comes down to personal preference. I had the Presa's when they came out and could never get used to them. I didn't like the "squashed" part of the tops of the bars because you had to have them in exactly one place otherwise the edge was always bothering my palms. I like round top bars for that reason... you can tilt them exactly how you like and the grip on top is always the same.
Exactly the flat straight area in the hoods are the thing I´m after.
I know Fizik Snake has the same (and a niceier bend) but they will not fit
- To big drop for a small frame
- The stem is -7
- The seatpost are 25 mm setback.
I had my eyes on Fizik for a while but I have almost made up my mind on
Superleggera seatpost
Zero100 Stem 120
Zero100 Shallow bar
To go with 48S Colnago C60.
Thanks for the pictures!
3Pio wrote:benzebub wrote:I like the Zipp service course sl-80 myself very much. I love the long drop section which gives me plenty of space to move around.
I also use Zipp Sl-80 and really like the long drop section. The only problem i have, which i can not solve is transition in the hoods. I have a small bump there, which make me uncomfortable after some riding. Im using it with Campagnolo, and to me look like maybe its not perfect match each other. Do u have the same bump? And what groupset do u use?
I also have ur question, and probably will try Deda Zero 100 next
p.s if u like to shorten the reach, maybe to put ur saddle a bit forward, and to compensate that raising in same time few mm?
benzebub wrote:3Pio wrote:benzebub wrote:I like the Zipp service course sl-80 myself very much. I love the long drop section which gives me plenty of space to move around.
I use both campagnolo (2015 chorus) and shimano levers (2 different bikes).
I don't have a big bump on the campa levers, I did however mount the levers a bit higher on the bar so they point upward very slightly. This position works well for me and the transition is smooth to the hoods.
