3T Funda Tire Clearance
I am running Vittoria Diamante 25's and they fit fine on a narrow Fulcrum 3 wheel.
Haven't calipered them though.
Bumping up an old thread. Has anyone tried 28mm (measured) tires on these forks?
28mm GP5000s just taken off my 1x with 3T funda pro: slight touching when the wheel picked up dirt, at the top: enough to make a very slight noise and a slight mark, but cosmetic only really. Too much of a perfectionist to allow it but I not really a problem.
Thanks for the input. I’m planning to run GP5000 clinchers. What size rim were you using?ghisallo2003 wrote: ↑Sat Jul 23, 2022 9:06 am28mm GP5000s just taken off my 1x with 3T funda pro: slight touching when the wheel picked up dirt, at the top: enough to make a very slight noise and a slight mark, but cosmetic only really. Too much of a perfectionist to allow it but I not really a problem.
It is a 700C DT Swiss RR415 so old-school narrow. You may have more luck with a wider rim that sets the tyre slightly lower. It would not need a lot to make it work.
