It is currently Thu Oct 19, 2017 9:43 pm
Post new topic  Reply to topic  [ 22 posts ]  Go to page 1 2 Next
PostPosted: Sat Jan 28, 2017 12:20 am
My Ritchey WCS Evo 42cm is 265 grams.
I'm looking at Zipp Service Course SL-80 listed as ~250 grams http://zipp.com/bars/service-course-sl-80---/#
What else is out there besides: Cinelli, Deda, 3T, Easton, FSA, Fi'zi:k, Shimano PRO
Remember, aluminum only.
:nospamhere:
PostPosted: Sat Jan 28, 2017 10:00 am
Check the 3T Ergosum Pro, 245g. It is a short drop, long reach model and I really like it. The Ergoterra is also quite similar, but it only has wider models.
The Ergosum graphics are a bit too loud, especially the white arc on the left side, but can easily be removed with acetone.
PostPosted: Sat Jan 28, 2017 11:22 am
I have Zipp Service Course Sl-80 in 42 cm c-c and actual weight is 264 gm
My friend have Fizik Cyrano R3 Bull and its 259 gm.
Why not carbon? Im in similar situation, but until now i cant find anything much ligher in alloy, so thinking to switch to carbon
PostPosted: Sat Jan 28, 2017 11:43 am
cannondale c1 alloy compact road bars..
250 grams in 45cc (44 according to the manufacturer, but actually 45cc)
PostPosted: Sat Jan 28, 2017 11:55 am
My 42mm cannondale c1 bars are 240g on the nose. I just got a 44mm but haven't had a chance to weigh it yet. There are ones that pop up on ebay often.
My Strava Profile
2016 Cannondale CAAD12
PostPosted: Sat Jan 28, 2017 8:00 pm
Online
I just weighed my cannondale c1 (40cm c-c) and it's 241g. Message me if you are interested. ;) BTW the ritchey wcs curve is 235g.
PostPosted: Sat Jan 28, 2017 8:19 pm
How did u find that weight for Ritchey wcs curve? And in which size? I just checked, the listed weight is 253 gm for 42 c-c (i expect heavier actual weight)
PostPosted: Sat Jan 28, 2017 8:26 pm
Don't ever trust manufacturer with listed weights. My Ritchey WCS Evo is listed 250 grams and it's 265 grams. Same thing with Zipp, ~ 15 grams weight discrepancy. The only place I trust is boutique https://fairwheelbikes.com/cockpit-seating
This is the reason I started this thread.
:nospamhere:
PostPosted: Sat Jan 28, 2017 8:29 pm
And, i still wonder what is general opinion about Carbon vs Non Carbon handlebar in 2017?
Why u dont like a Carbon handlebar?
PostPosted: Sat Jan 28, 2017 9:02 pm
oh, and one more hint:
get the cheapest bartape from ebay. those weigh 33 grams in pair with end plugs! you can use either hair lacquer underneath the tape, or just tape it firmly, and it wont slip.
just the cheapest hit for "handlebar tape". around 1.5 usd.
PostPosted: Sun Jan 29, 2017 12:34 am
Online
You are right, I used the listed weight (here: https://ritcheylogic.com/wcs-curve-blatte-road-bar). I've never had anything from Ritchey that weighed more than their spec, but maybe I'm just lucky.
@3Pio: a lot of people don't like carbon cockpit components. Personally I use alloy stems and carbon handlebars, but I completely understand if somebody trusts alloy better.
PostPosted: Sun Jan 29, 2017 8:42 am
It would be really good if someone can measure this Ritchey WCS Curve handlebar for actual weight. If it's really 235 gm, then maybe the best alloy compact hb.
About carbon vs alloy, im using alloy and no problems with comfort. But thinking to go to carbon because i want to shave some weight.Still did not switch to carbon, because i find out the very light ones are not stiff enough. And if i go to a bit heavier but stiff, then no weight saving that is worth to switch for
PostPosted: Sun Jan 29, 2017 12:30 pm
My 42c-c wcs evocurve weights 253gr.
My 42c-c wcs classic weighted 239gr.
My 6708gr TIME Skylon
My 9733gr COLNAGO Master X-light
PostPosted: Sun Jan 29, 2017 3:34 pm
Pro vibe 7s.
PostPosted: Sun Jan 29, 2017 3:51 pm
Here you go
Cannondale C1 42mm
Cannondale C1 44mm
My Strava Profile
There are no new unread posts for this topic. Compact Handlebar with Flat Top?
daveydoo
24
1829
Thu Aug 17, 2017 2:47 pm
daveydoo View the latest post
There are no new unread posts for this topic. Finishing handlebar tape with RS910 handlebar junction connector
raggi
9
1144
Wed Aug 02, 2017 4:28 pm
dfischer1 View the latest post
There are no new unread posts for this topic. Compact v semi compact
wilwil
35
2035
Thu Jul 27, 2017 11:05 pm
shimmeD View the latest post
There are no new unread posts for this topic. So Dogma F10 shaved a few grams and now flexes...
ninjasloth
13
2078
Mon Jun 05, 2017 4:01 am
Seedster View the latest post
There are no new unread posts for this topic. Attachment(s) Aluminium frame + Dremel = How many grams lost?
SABARRAS
23
2921
Wed Feb 01, 2017 4:42 pm
darnellrm View the latest post
Users browsing this forum: axiom, Baidu [Spider], Bing [Bot], Google Adsense [Bot], jb, JoeFlan, PinaF8, ride1970, Sleepless and 35 guests
