s works 6, pain only in right foot??
by em3
DartanianX wrote:
em3 wrote:...I found the super thin carbon sole on the S-Works 6 shoes require VERY short cleat screws (in my case 6mm using time RXS cleats)....r u sure that the pain wasn't caused by one of the cleat screws poking through the insole? EM3
Hence why Spec supply cleat bolts with the shoes. Should be used regardless.
Sent from my Pixel XL using Tapatalk
The bolts supplied with the S-Works 6 shoes are 8.5mm long...still too long when using Time RXS cleats. Not to mention the Specialized bolt head is too wide, which slightly limits some of the fore aft adjustment of the RXS cleat. I was forced to Dremel the 10mm Time bolts down to 6mm in order for them not to protrude through the insole. EM3
