It is currently Tue Oct 17, 2017 9:26 am
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Wed Jan 25, 2017 6:25 am
Hi everyone,
Can anyone advise on what this threaded hole is for in my new pair of Sidi Shots? I don't recall seeing this particular hole in my old pair of Ergo2s.
http://www.hackracer.com/
PostPosted: Wed Jan 25, 2017 6:29 am
Its for some (all?) Look cleats with a detacheable middle keying piece for replicating cleat position when replacing cleats.
PostPosted: Wed Jan 25, 2017 6:30 am
It's for "Look position memory".
The” position memory” LOOK patent easily allows the adjustment of your cleats when you need to change them. In order to use this system, the sole of your shoes must have a central oblong where the memory position part will be screwed.
Amaro Loren
Colnago C60 -Done and dusted-
Cannondale SuperSix Evo -Sold-
PostPosted: Wed Jan 25, 2017 7:29 am
Thanks everyone!
Do you guys and gals use this feature? Previously I just took a silver sharpie (marker) to draw an outline of the cleat before unbolting it.
PostPosted: Wed Jan 25, 2017 10:45 am
Online
IMHO, sharpie better. I don't ride look anymore but tried this out a couple years back. Maybe I was doing it wrong, but the key piece would shift a little bit when uninstalling cleat.
Initially I didn't want to take a sharpie to my expensive shoes, but I realized the soles were beat up anyhow...
AX Lightness Vial Evo, Carl Strong Titanium
PostPosted: Wed Jan 25, 2017 11:31 am
I've never figured out how to use position memory. I've always used look cleats on sidis but I don't get what's meant to screw into that fourth threaded hole.
Can anyone enlighten me/us?
PostPosted: Wed Jan 25, 2017 12:22 pm
You use the 2 bolts supplied with Sidi shoes. When you remove the 3 bolts from the old cleat, the memory pad stays in position. Remove the memory pad from the new cleat first and then fit the new cleat over the old pad which aligns it on the sole.
PostPosted: Wed Jan 25, 2017 12:53 pm
I see. Didn't realize the shoes came with a pair of bolts... it's been a while. Thanks for the tip
PostPosted: Wed Jan 25, 2017 2:06 pm
I use both Sharpie and memory pad.
PostPosted: Wed Jan 25, 2017 7:39 pm
If you don't use the Look memory thingy, that "middle nut" may slide back and forth freely in the slot, which is a bit of an irritating sound. I've fixed that problem by inserting a small piece of brake casing in the slot.
PostPosted: Thu Jan 26, 2017 2:51 pm
... or a dap of superglue if you know you're never going to use it. That's what I've done my shoes and my wifes shoes. Both use Speedplay and I can't see us ever going to anything else...
PostPosted: Thu Jan 26, 2017 3:13 pm
Never have used this and also had no idea what is was... My fiziks have it aswell and it moves around making noise.
There are no new unread posts for this topic. Sidi speedplay only white? Sidi 2018?
Tommo
Tue Oct 17, 2017 8:11 am
probertsqbe View the latest post
There are no new unread posts for this topic. Attachment(s) Fork Needed - straight, carbon, 1" threaded steerer - suggestions?
dadoflam08
12
498
Wed Jul 26, 2017 11:31 am
dadoflam08 View the latest post
There are no new unread posts for this topic. Shoes, shoes, not all of them created equal
vejnemojnen
13
1695
Wed Apr 19, 2017 11:57 am
Junior7 View the latest post
There are no new unread posts for this topic. what's the hole in the frame for BMC SLR?
addictR1
Fri Jul 14, 2017 5:32 pm
addictR1 View the latest post
There are no new unread posts for this topic. Attachment(s) HELP! Canyon Endurace AL: HOLE IN FRAME!
elephant
10
1046
Fri Sep 15, 2017 10:55 am
phlip View the latest post
Users browsing this forum: Bing [Bot], gtv18, PinaF8 and 31 guests
